04-13-2009, 07:20 PM | #1 |
Chemist under the hood...
What engine is this?
This is a picture of the engine in my 1967 GMC 910 pickup. It has a 4-barrel Quadrajet 4MV (17058213) on it. The block is orange and so are the valve covers.
I can't seem to find an engine code that makes sense. The one stamped on the block near the water pump shows 505506367 (the first digit could be a six). The number cast on the top of the engine behind the carburetor shows 628375 and a K3 under it. It's a V8 but is it a 283 or what? It's not the engine that came with the truck since the truck's VIN shows a I-6 engine. I took a picture to see if anyone has an idea on where else to look for a number. The engine is so grimy from years of farmer oil-spray that the numbers I did get took awhile to find! Thanks in advance! |
04-13-2009, 07:28 PM | #2 |
Re: What engine is this?
area #1 is a machined flat spot on the passenger side of the block just in front of the cylinder head, look for the suffix there (2 or 3 digits) and area #2 has the block number cast into it. It's just above the bellhousing and is more difficult to read (faces rearward and smashed between engine and firewall)... Use some brake cleaner and a rag to clean them off... Numbers on the intake or cylinder heads won't give you all the info...
Let us know what those numbers are...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-13-2009 at 07:29 PM. |
04-13-2009, 07:41 PM | #3 |
Thanks for the picture-where your number 1 position is, I have either 50 5506367 or 60 5506367. Does that make sense?
04-13-2009, 08:06 PM | #4 | |
04-13-2009, 08:07 PM | #5 |
those don't sound right.. got pics?
here is a link to a good site http://www.nastyz28.com/chevy-engine-code-stampings.php or this http://www.chevymania.com/partsid/su...fm?block=Small
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-13-2009 at 08:08 PM. |
04-13-2009, 08:43 PM | #6 |
Green club
Well, that carb is off of a 1978 48 state Chevrolet with a manual trans.
So,if that carb is original to the engine, it's most likely a 305 or a 350 out of something somthing 1978. Sorry, I can't find too much on the numbers you posted. Try the numbers on the back of the drivers side block, where the trans bellhousing bolts up to it.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
04-13-2009, 09:36 PM | #7 |
I will get some pictures tomorrow of the numbers on the front so you can see for yourself. Also, I'll try to degrease around the back end to see if there is anything better there.
The last owner said it was a 283 but that's what I want to know. Great responses to my questions-thanks, |
04-13-2009, 09:38 PM | #8 |
are there any accessory holes in the front of the heads? to mount an alternator and such? If not then it's older than 69...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-13-2009, 09:48 PM | #9 |
That's another post. The only spot I can see is where the alternator attaches-driver's side way down low. I'd like to move the alternator so that the tension can be adjusted better but I don't know what bracket set to look for without the engine info.
The adjusting bracket shares a bolt with the water pump. The lower bracket is bent or not correct. I can't see any other spots to attach any other equipment. When I picked this up two weeks ago, the belt was slipping so bad you could turn the fan freely with hardly any resistance. I re-aligned and adjusted the adjusting bracket to the lower bolt on the water pump. The alternator still sits tilted to the rear but at least the belt makes contact. Frustrating! |
04-14-2009, 06:59 AM | #10 |
My alternator attaches to the exhaust manifold and water pump.. without holes in the heads you are rather limited to your options unless you steal parts from a 67/68 V8 or go aftermarket brackets.
04-14-2009, 10:43 AM | #11 |
looks like my 307 I have sitting in my garage, but with a newer style t-stat housing
Any luck on those #s yet?
1967custom |
04-14-2009, 11:29 AM | #12 |
Its a Truck Thing......
Well,
Having no holes in the heads makes me think that it could be a 283/327. 283 stopped in 67. If I recall, 327's also came without holes in the head too. I know someone will chime in. Just a thought, and owning one, it looks like mine. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
04-14-2009, 12:37 PM | #13 |
Rods
if im not mistaken the 283 would have a oil fill in front of the engine. and no pcv.. also what side is the dip stick on... what about the crank pullys and banalcer.
04-14-2009, 12:41 PM | #14 |
Rods
283,327,307,305 dip stick on drivers side
04-14-2009, 01:39 PM | #15 |
did 350s not have the dipstick on the drivers side because i have a 350 and my oil dipstick is on the driver side?
04-14-2009, 02:08 PM | #16 |
Rods
what year is yours. what year is the oil pan from
04-14-2009, 02:14 PM | #17 |
I have a 1977 350 hei 4 bolt main and the dipsticks on the driverside
1967custom |
04-14-2009, 03:23 PM | #18 |
Mine did have the oil fill in the front with the original 2bbl configuration, then I changed it. The dipstick on mine is on the drivers side. Then I put a pvc on it.
Smitty
04-14-2009, 04:10 PM | #19 |
one is a 69 and one is a 71
04-14-2009, 07:37 PM | #20 |
Ok-some more pictures. Still can't see numbers that make sense. One shot is up close on the block near the water pump. The other is on the top of the engine behind the carburetor. Anyone know what that bolt is doing there?
04-14-2009, 08:21 PM | #21 |
That bolt is blocking the vacuum T fitting in the intake..
look behind the driver side head near the bell housing for the casting numbers.... Those other numbers look more like a VIN from the factory, some had that too..
04-14-2009, 08:53 PM | #22 |
Thanks Cpt.Mike. What would normally attach to that vacuum fitting?
04-14-2009, 09:03 PM | #23 |
Power Brake Booster....
Smitty
04-14-2009, 09:15 PM | #24 |
Ok-Well that's not a problem since I just have manual brakes! I'm getting good leg exercise.
04-14-2009, 10:26 PM | #25 |
yep, you could get a plug to install and pull the angle fitting out, but why bother if it's sealed...
