What exactly do you do to the driprail when restoring? Do you caulk it or what? I am getting ready to start removing the rusted areas around the sides of the cab on the driprails, but I am unsure of the steps I need to be taking......I guess you could say I'm running blind.
Thanks, Greg |
Hollister Road Co.
Re: Driprails............
do a search on Joint and Seam Sealers, you'll find what you need
Built 4 Speed
grind them off and weld it back up. thats just me.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
Under Construction
you can search, and you can also visit your local paint supply store. Wire wheel the drip rails really good, take care of any rust issues at the seams. you will want to use a good self-leveling seam sealer. you can post in the paint and body section, or ask your local supplier as i have seen some ppl put the seam sealer directly on cleaned bare metal, and i have seen some ppl epoxy prime, then apply the sealer, then paint body color.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 04-15-2009 at 08:53 AM. |
