Old 04-16-2009, 04:07 PM   #1
3r!c84
Badass
3r!c84's Avatar
carburetor
how do i know if my back flaps are opening when i floor it?it dont seem to be opening/
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 04-16-2009, 08:11 PM   #2
85Bowtie
85Bowtie's Avatar
Re: carburetor
It depends, what kind of carb do you have? New? Used? Vacuum or Mechanical?
Usually there is a "kick" when the secondaries open, however, that's also a sign of a deadspot which isn't a big deal but is a pain to get rid off.
If anything, you should feel somewhat of a resurgance in power, in other words, it gets noticeably faster.
On my Diplomat cop car, I can "hear" it open, you can't rev that high on only the first 2 barrels that quickly when you nail it.
If you can't feel a "kick" and your carb runs good, then you have it tuned right and you shouldn't worry.
What makes you think they aren't opening?
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-16-2009, 09:12 PM   #3
73chevyman
73chevyman's Avatar
Re: carburetor
if you have a stock aircleaner flip the lid you'll hear them. like a sudden rush of air. also check to see if your linkage is working with the truck off you'll see them open up. jack
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-16-2009, 09:35 PM   #4
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
its the stock carb.roghester quadrajet .it has a knn air filter,and i dont feel it open it realy lags when u floor it
-00 Saturn 5spd
1/4:13:90
Old 04-16-2009, 10:22 PM   #5
enaberif
Re: carburetor
Lag is another issue.
But with my 4" open air filter when all 4 are open I can physically hear the engine tone change and it makes me giggle like a school kid
enaberif is offline   Reply With Quote
Old 04-17-2009, 07:58 AM   #6
85Bowtie
85Bowtie's Avatar
Re: carburetor
There's your problem.
Ditch the quadrajunk and get a Holley or Edelbrock.
Some people will tell you Q-Jets are great but I've never had any luck with them. They're tempermental carbs and a PITA to rebuild IMO.
You could play expert mechanic and learn the tricks and how-to's of the Q-Jet. Or, you could save time and enjoy driving your truck more often by just switching to an Edelbrock.
Old 04-17-2009, 08:40 AM   #7
OrangeAnimal
OrangeAnimal's Avatar
Re: carburetor
I can build the quadrajet carb to be a amazing carb but it does take alot of work and a good core to use which is getting harder to find at the junk yards. I would suggest using a Edelbrock. I do not care for Holley on a street driven truck. I really haven't had much luck with them. They take alot of work to tune and although it's worth it in the end they are more for getting max power out of a engine and not so good with fuel mileage.
My .02 cents. Good luck.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-17-2009, 09:11 AM   #8
85Bowtie
85Bowtie's Avatar
Re: carburetor
I'm the opposite, I can tune/rebuild any Holley/Edelbrock/Carter even the thermoquad.
I've got a Holley 870 on my 440 that runs fine on the street or track, doesn't even run slightly rich.
Everything else I use Edelbrock.
The Q-Jet is a Pandora's Box I am unwilling to open.
Old 04-17-2009, 03:06 PM   #9
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
yea im thinking about a new carb.but idk if a Vacuum line or something is rong?
on the passinger side under the choke there is a retaner thing that hold the back flap from opening?
but when i move that with my finder and floor it the back flaps open?
idk if that retaner thing moves my vacuum or what? I've looked all around that thing and cant find out how that thing opens?
-00 Saturn 5spd
1/4:13:90
Old 04-17-2009, 08:45 PM   #10
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: carburetor
Sounds like a bad accelerator pump or a clogged fuel filter. Both cheap & easy to check.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 04-17-2009, 09:46 PM   #11
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: carburetor
there is a little spring adjustment on the secondary throttle valve that causes the bog most times
powerdriver 1958 is offline   Reply With Quote
Old 04-17-2009, 10:31 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
what is a accelerator pump and where is it at?
-00 Saturn 5spd
1/4:13:90
Old 04-17-2009, 10:54 PM   #13
sierra4x4
sierra4x4's Avatar
Re: carburetor
I always rip off the link that is on the pass. side above the choke housing that goes back to the secondaries on the top. Those things almost always hold the secondaries closed.
I hope that makes sense.
sierra4x4 is offline   Reply With Quote
Old 04-17-2009, 10:55 PM   #14
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
lol not at all
do u got a pic or somthing
-00 Saturn 5spd
1/4:13:90
Old 04-17-2009, 11:13 PM   #15
sierra4x4
sierra4x4's Avatar
Re: carburetor
I found a pic of the link that I was talking about.
Old 04-17-2009, 11:36 PM   #16
PhilaTruck
PhilaTruck's Avatar
Re: carburetor
I'll assume you have a mostly stock engine?
The accelerator pump is the rod that's activated by the lever on top of the carb (drivers side). You need to remove the top of the carb to replace it.
Also, a dirty carb can also cause poor performance. A rebuilt kit will cost about $20.
Here's a great link to info for tuning your Q-jet. You'll see there's text about 2/3rds down the page referring to the secondary air valve that I think Powerdriver mentioned.
Mike Ervin's & Damon Nickles' excellent Q-jet tuning tips
Here's a link to a parts supplier. carburetion.com
Subscribe here!
Old 04-18-2009, 09:51 AM   #17
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
ok i understand where its at but what do that rod do?
-00 Saturn 5spd
1/4:13:90
Old 04-18-2009, 10:33 AM   #18
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
this is not my carb just a pic i found.
the white thing is hiting the green
-00 Saturn 5spd
1/4:13:90
Old 04-18-2009, 12:32 PM   #19
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
me and my dad talked and im just going to buy a new carb. i allready got a performer intake waiting so ill just save up a lil $ and buy something new
-00 Saturn 5spd
1/4:13:90
Old 04-18-2009, 12:40 PM   #20
piecesparts
Parts and more parts
piecesparts's Avatar
Re: carburetor
Are you absolutely sure that the carb is a Rochester Quadrajet. There is a reason for this question---Carter ALSO made quadrajets and the carter carb has some defiencies in their design. The needles for the secondaries pass through the carb body in openings that tend to errode away and when you accelerate the bogging issue that you described may exist. So to eliminate the bog most drivers would tend to ease through that transition area.
The Rochester carb bodies has a brass insert in that area and did not errode, so the transition from the primaries to the secondaries was better and more prevalent. Also your bogging could be from the surge from your accelerator pump.
Old 04-18-2009, 01:07 PM   #21
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
I am absolutely sure that the carb is a Rochester Quadrajet
it says Rochester Quadrajet
17082226
1612duu
-00 Saturn 5spd
1/4:13:90
Old 04-18-2009, 02:39 PM   #22
Pyrotechnic
Pyrotechnic's Avatar
Re: carburetor
Here's the thing, if you have a Quadrajet and the secondaries are opening too soon or not soon enough, and the engine runs good otherwise, switching to a different carb is not the answer. The fact is, the secondary air door on the Quadrajet is easily adjusted to open sooner or later.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-18-2009, 03:06 PM   #23
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
its not opening at all ,ive been reading up on this carb and they put the same carbs on 305-454s so its way to much cfm for this motor ,thats why the backs are not opening.
-00 Saturn 5spd
1/4:13:90
Old 04-18-2009, 03:07 PM   #24
3r!c84
Badass
3r!c84's Avatar
Re: carburetor
and if u can adjust it,how would you adjust it?
-00 Saturn 5spd
1/4:13:90
Old 04-19-2009, 03:00 AM   #25
Pyrotechnic
Re: carburetor
Not true. The secondary air door will open on a weakling 305 if it is adjusted properly.
