Old 04-19-2009, 09:51 PM   #1
Mike68stepside
Instrument gauges?
I have a 68 without instrument gauges and have chance to buy complete instrument panel with gauges. Question is, will the clip work on the curcit board to operate the fuel gauge, directional signals, high and low beam indicator and how would you hook up the tempature guage and ampmeter. I realize the speedometer and oil presure have individual lines. Thanks for your help!
Mike68stepside is offline   Reply With Quote
Old 04-19-2009, 10:08 PM   #2
69lemans
Re: Instrument gauges?
Some info here about how to rewire your harness plug
http://www.gmcpauls.com/Tech%20Tips1.htm
69lemans is offline   Reply With Quote
Old 04-19-2009, 10:19 PM   #3
Mike68stepside
Thumbs up Re: Instrument gauges?
I have looked at this site, however, I do not have idiot lights and switching to guages. Any other help?
Old 04-19-2009, 10:32 PM   #4
Green Machine
Green Machine's Avatar
Are you doing an aftermarket gauge setup ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-19-2009, 10:37 PM   #5
Mike68stepside
This is not an after market set up. I have a donor truck that had the complete guage cluster, but wanting to switch to the stepside.
Old 04-19-2009, 10:40 PM   #6
Green Machine
If they both are 67-72 and both originally came with gauges then it is a direct swap.
Old 04-19-2009, 11:00 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm a little lost here too.
You have a truck, with no guages at all.... the whole inst panel is missing? And you've located a complete inst panel, and want to know if it'll fit?
Or do you have a truck with the acc guages, but no tach, and you located an inst panel with a tach in it and want to install it.
Old 04-20-2009, 01:38 AM   #8
truckster
truckster's Avatar
I agree with Longhorn Man that it's kind of hard to follow this thread. If there's any way you can post pictures of what you have and what you want to install, that would make the question a lot easier to answer.
truckster is offline   Reply With Quote
Old 04-20-2009, 01:51 PM   #9
Mike68stepside
Sorry for the confusion. My truck has instrument panel, but only has the speedo and fuel guage and turn signals. The donor panel (from 1970 GMC) has the above and oil pressure, temp. guage and ampmeter. Neither have the tach. Trying to install donor panel and hook up so every thing works?
Old 04-20-2009, 02:03 PM   #10
my67chevytruck
Under Construction
my67chevytruck's Avatar
if your gauge looks like this... you had an idiot light gauge originally and will need to rewire as shown on the gmcpaul website.
If you had the 7-hole guage, then you can just plug in another 7 hole gauge and be good...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-20-2009, 08:56 PM   #11
Mike68stepside
You are right. I am the idiot, my guage cluster looks like the one you show. Now, do you know how to pull the plugs out of the old plug and move to the new spots?
Old 04-20-2009, 03:48 PM   #12
Longhorn Man
yep, the link above is what you need to do to make it work.
DON'T just plug it in. You WILL cry.
Trust me.
Your friends will laugh... mine was laying in the dirt ready to pee himself.
That was a bad day.
Old 04-20-2009, 08:58 PM   #13
Mike68stepside
Apparently you have done this before. Do you know how to pull the pins from the old plug?
Old 04-20-2009, 09:28 PM   #14
Longhorn Man
I never got around to it on that truck, and all the ones I've had since then had the optional panel.
Old 04-20-2009, 09:29 PM   #15
my67chevytruck
Under Construction
Mike,
I personally have not done this. Andy (longhorn man) has. I believe with a small flat screw driver you can release the pins, pull out and push back in the correct spot, but i am not 100%
Edit **** just read Andy's post.. Others should chime in, that have does this conversion....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 04-20-2009, 09:31 PM   #16
Longhorn Man
lol! I hit enter as you were typing! No, I haven't done it... I just suffered the humility of thinking it was plug and play.
My fuel guage never worked right again.
Old 05-25-2009, 04:35 PM   #17
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
I am in the process of doing this now and to remove the tabs follow this: Stick a skinny/small flathead screw driver underneath the front of the pin , push back as far as you can and lift it up, some make a tiny little pop noise when released, others don't - you are basically releasing/bending the metal tab holding the pin in there. Next stick the small screwdriver on the back of the pin where the wire goes in and slowly pry it out using the black plastic holder as leverage. I bunged a few pins up as I learned this process, but after a couple it became easy, just be careful and take your time. You will have to rebend the metal pins back out so that when you slide them back in they will hold again...hope this helps!
Beatcoaster is offline   Reply With Quote
