04-20-2009, 01:46 AM | #1 |
motor I.D.
anybody got any thing on this elusive subject? I checked out year one and nastyz28.com or something like that and if I'm reading it right I think my motor is a 275 hp 327 cid cast/built in canada on august 24 1966. any input or thoughts would be welcome.
66 red and white gmc 350ci 700r trans now a project truck will be my daily driver rat rod 66 burgundy and white gmc 283ci th350 trans gotta ton of good parts current project old school rulez, West Coast Canadian style |
04-20-2009, 10:56 PM | #2 |
Sunburst C10!!!
Re: motor I.D.
can you post some vin and casting numbers
Gage 1967 C10 Shortbed Stepside |
04-20-2009, 11:40 PM | #3 |
60-66 Nut
Re: motor I.D.
......And the code off of the pad in front of the passenger side head
04-21-2009, 12:07 AM | #4 |
Re: motor I.D.
I simply googled chevy engine decoding and vwalaa.I decoded my engine down to it's original birth vehicle.
04-22-2009, 01:58 AM | #5 |
Re: motor I.D.
the front number is K1208HC the problem is all the codes I've seen as examples are 8 digit. as you can see mine is 7 digit. pretty sure its a canadian 327 275hp but I cant tell which car. the date code is h246 which I beleuve is august 24, 1966. 3903352 is the code off the drivers rear.totally in the dark on that one. thanks
04-22-2009, 02:18 AM | #6 |
James
Re: motor I.D.
year casting# CID HP,low HP,high Main vehicle
1967 3903352 327 210 350 2 cars only Suffix code... (K) St. Catherines, Ontario (1208) Jan. 20 1968 HC 1965 327 Powerglide 275 4 full size HC 1969 350 m/t 250 2 A F X
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
04-22-2009, 09:59 PM | #7 |
Sunburst C10!!!
Re: motor I.D.
sounds like it to me
04-24-2009, 11:04 PM | #8 |
Re: motor I.D.
thanks guys
