04-22-2009, 02:46 AM | #1 |
my 1976 Beast going through transformation!!
Here's the begining!
Got the mouldings off and going to start welding the holes. also got a pic of my son at the wrecking yard, pulling 1/2 ton coil springs so we can drop the 3/4 ton beast! thanks to the awesome info on this site!!!!!!!!!!!!!!!!!!!!! |
04-27-2009, 01:19 PM | #2 |
Re: my 1976 Beast going through transformation!!
Ok here's what we did this weekend!! Dropped the front end 3 inches! Had got 1/2 ton springs and put them on and didn't move!! So we cut 2 coils off the 3/4 springs and "BAM" down it went!! Still debating on what I'm going to do with the rear? Thought about drop shackles and taking some leafs out or just do the flip???????????????? hum hum hum?????
04-28-2009, 07:21 AM | #3 |
Looking nice! I'd say a flip kit in the rear. That would make the stance real nice.
04-28-2009, 03:22 PM | #4 |
thanks turbo!! really starting to lean that way!!
04-28-2009, 03:59 PM | #5 |
Low & Fast!
Looks like some work to me.. Keep that moulding it is getting hard to come by, I am kicking my a$$ for giving mine away.. And looks good..
04-30-2009, 04:01 PM | #6 |
Chevys Kick A$$
Sweet looking truck its looking good so far. Should look great when the back gets closer to the ground. My vote is for a flip kit in the rear as well just my .02 cents.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-30-2009, 04:08 PM | #7 |
1962 C-10
Looking good! If that trim you took off is getting in your way, send it my way!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
04-30-2009, 05:17 PM | #8 |
Alot of the trim got damaged when we took it off. I took it off before I found this awesome site full of info!! or I would of asked for the best way to get mouldings off without damage!!!
05-03-2009, 01:11 AM | #9 |
Ok wanted to see what it would look like if I took some plates out of the leaf springs!! So here it is!! Not to bad!! What you all think??????
05-03-2009, 02:50 AM | #10 |
6.0 powered square
looks good you can get 2" drop shackles at any auto parts store cheap
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
05-11-2009, 02:04 PM | #11 |
Got a ? what do you all recomend for filling the moulding holes?
05-11-2009, 04:02 PM | #12 |
6.0 powered square
I would weld them up
05-11-2009, 10:05 PM | #13 |
yeller
Welding them up is the only way to go IMO.
Truck looks great! I do think I would like it better with the trim however.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 05-11-2009 at 10:06 PM. |
05-12-2009, 03:08 AM | #14 |
Sb 400 club
great project! I liked it better with the trim but it looks good dropped like you guys did. Keep up the good work
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
05-15-2009, 10:14 AM | #15 |
Nice looking truck! Are you planning on leaving the 8 lugs? I really like the stance. I too agree with others, the trim would have made it look even better.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
05-18-2009, 12:20 AM | #16 |
Cheyenne Super
I would have kept the trim too.
Keep it 8 lug for sure, you'll have a better choice of wheels. |
06-05-2009, 03:06 AM | #17 |
looking good bro
06-14-2009, 08:14 PM | #18 |
You might want to remove the front bump stop mounts if you haven't already done so. Also replace the upper a-arm bolts with longer units to allow for alignment and you will more than likely need a spacer between the shims and the chassis otherwise your shim stack will be an inch give or take thick.
Reminds me of mine when I first dropped it.
1979 C20 pickup 454 big block turbo 400, 4.56 gears |
06-15-2009, 01:47 AM | #19 |
thanks!! ya I already buzzed off the front stops. but was wandering what to do with the wheels being so slanted? so where would you suggest I go to get the longer bolts and shims?
10-02-2010, 09:31 PM | #20 |
flip kit in the rear with the trim on as well
