Wood Bed Advice
Sorry, I am sure this has been covered a million times.
I need to do my wood bed in my 68 longbed. Does anyone know the exact measurements of each board? Or is there a guide book out there somewhere I can pick up? I know the boards are 3/4" think, but they are different widths and I am not sure on the exact length to fit in the longbed properly. Also, I only finding 1'' thick boards at my local Lowes and Home Depot. Will that thickness work? Just seems like I could do this for a lot cheaper than buying a pre-cut wood kit. They are so expensive. I have a shop and all the proper tools. Or does anyone know where to get a killer deal on a pre-cut wood kit that will not kill me on the shipping? Thank for any help!
-mgf- 1968 Chevy LWB.
Lowered. 15x7 rallies and BFG's. Built 350. Dual Flowmasters. Fast and Loud. |
GMC Pauls has that info. Here's a link. Hope this helps?
http://www.gmcpaulstruckparts.com/47...dWood_Info.htm
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Re: Wood Bed Advice
Awesome! Thank you.
Grandpa in the rustmobile...
Re: Wood Bed Advice
do u gotta take the bed off to replace steel floor with wood?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Wood Bed Advice
dunno know. i would guess that it is easier to cut out the metal floor with it removed, but I am sure you could do it without removing the bed.
Re: Wood Bed Advice
If you have the tools find someone local with a sawmill and have them saw you some lumber. They can cut whatever thickness you want and it's cheaper than lowes, etc. White Oak is about the best as far standing up to the elements.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
I really hate wet sanding!
![]() Join Date: Dec 2008
Re: Wood Bed Advice
The boards you are finding at lowes and home depot are 3/4" wide. I know they are called for instance a 1 x6" but they are actually 3/4 x 5 1/2. The one by measurement is what the board measured from the saw mill prior to thickness planing.
![]() Join Date: Jan 2009
Re: Wood Bed Advice
if you have the shop and the tools, i would look around and see if i could find some old lumber like from a barn and resurface it. yes it would be a job,but i have seen this done a few times and that old lumber looks great!
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
Re: Wood Bed Advice
good seeing this, I am wanting to do a wood bed floor on my truck when i find one.
Re: Wood Bed Advice
I have a wood floor on my Box that was rotted bad.I took a better looking piece of the floor to the local wood store that I had cleand up and it was cut from Douglas fir. Now my truck was built in Oshawa Canada.So what was the types of wood was used back in the day or did they just use wood that was good & easy to get a hold of ?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 05-26-2009 at 09:57 AM. |
Re: Wood Bed Advice
If you use GMC Paul's measurements to groove your own bed wood, just remember that those measurements are taken from factory cut boards with GM metal strips. I found out the hard way that my aftermarket stainless strips are not as wide and don't fit as deep into the groove as the originals, and I had to re groove my boards.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
