Old 04-25-2009, 11:03 AM   #1
bad_burb
bad_burb's Avatar
1/2 to 3/4 ton swap.
I just want to confirm that the 3/4 ton rear leaf spring brackets, and shackles are the same dimensions as the 1/2 ton. So theoreticly I could take a whole 1/2 ton rear with springs and shackles and bolt it right in a 3/4 ton frame?
'73 C-30 3+3 Dually 454/TH400
'74 Fleetside 350/TH350 (SOLD)
'69 Nova 350/TH350 (project FOR SALE)
'63 Nova 305/TH350 3.73 posi (the wife's project)
bad_burb is offline   Reply With Quote
Old 04-25-2009, 11:31 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1/2 to 3/4 ton swap.
Member bagged74 just did this with his old crewcab.
I believe the leaf spring perched are positioned wider on the 3/4 tons,... so the 1/2 ton perches will have to be moved out wider to set correctly on the 3/4 ton leaf springs.
Keith
Convert to disc brakes.
Old 04-25-2009, 11:39 AM   #3
bad_burb
bad_burb's Avatar
Or could I use the 1/2 ton frame brackets? What did you do on your Crew cab? Thanks for the help.
Old 04-25-2009, 01:37 PM   #4
sierra4x4
sierra4x4's Avatar
1/2 ton and 3/4 ton have the same spring perch width. It's the 1 ton that is different. The 1/2 ton stuff will all bolt to the 3/4 ton hangers as long as the springs are the same length.
sierra4x4 is offline   Reply With Quote
