Old 04-27-2009, 07:20 PM   #1
SilveradoDude
Question License plate lights question
What kind of voltage should I be reading from the rear license plate lights?
SilveradoDude is offline   Reply With Quote
Old 04-27-2009, 08:02 PM   #2
73chevyman
73chevyman's Avatar
Re: License plate lights question
12 volts
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-27-2009, 08:40 PM   #3
billnorman
that's D.C. A better checker than a voltmeter is a test light. I use a brake light bulb with meter leads soldered to the contacts. Wrap the bulb socket in tape after you attach the wires to it. If the bulb lights brightly, you have a good connection and a good ground. You need power, volts doesn't always mean you can get enough amps to run anything.
billnorman is offline   Reply With Quote
