04-28-2009, 02:47 AM | #1 |
electric fuel pump.
So a few weeks ago I picked up a Blazer tank to put under the bed of my pickup. The tank was out of a fuel injected Blazer so it has an electric fuel pump. I want to run it as is because I want to have an electric fuel pump after I get a big block in my truck. So what do I need to do to hook it up? Is there any way I can run it to my stock fuel gauge? And I'll have to put a toggle in my truck to turn it on right? Or is there any way I can wire it in to the ignition. Thanks for the help guys. I'm really lost on this one!
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
04-28-2009, 04:10 PM | #2 | |
Re: electric fuel pump.
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
04-28-2009, 11:33 PM | #3 | |
60-66 Nut
The Blazer sending unit may be able to be modified to work. Try sending a PM to Vin63 here on the board. He know his stuff with sending units....he was rebuilding them for a while It would probably be best to wire the pump to a key on source thru a relay as the factory did. And a fuel pressure regulator with a return line is a must.
