![]() Join Date: Sep 2006
What's my ratio?
I marked a spot on the driveshaft and then turned my hub and counted the revolutions. My driveshaft only went around a little less that 2 turns to the hubs 1. So, what's my ratio?
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
![]() Join Date: Jul 2004
Re: What's my ratio?
Turn the wheel around twice, or if you have the time, turn it 20 times, that will get you a spot on answer. For instance, if you turn the wheel 20 times and the ds goes around exactly 41 times, you have a 4.10 rear.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
The Older Generation
You can look on the housing (for Location see the pics below) then go here and look up the code: http://www.americanclassic.com/paint.htm You just need the first two or three letters.... LockDoc
Ok, I tried it again and got this
Wheel/DS 10/18 20/37 30/56 I don't understand your math, but according to that would that make mine a 3.73??
Yes. 3.73. Now put a posi in it, and your golden.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
How do we come up with 3.73?
3.73 would aprox.3 3/4 driveshaft turns to 1 axle turn.You`re coming up with around 2:1.
![]() Join Date: Apr 2005
For a "one legger" I always multiply by 2......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
GEARHEAD
Because of the spider gears, if you have one wheel down and not turning, the ratio is half. If you were to roll the axle, both wheels down, the pinion would turn twice as fast. I just did this myself friday and figured it out. I don't think it works this way for a posi axle, but I'm not positive of that.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
I still don't understand the reasoning, but I would trust it to be a 3.73 long before 1.80.
I had my check and it came up with a2-1 the friend checking it said was coming up right so i pulled the cover it was a 373
