12-27-2002, 04:20 PM | #1 |
Overworked and Underlaid
Series of Questions
ok guys got a series of questions for you?i just ordered some headers,mufflers and pipes from summit racing a little while ago to fix the screwed up exhaust system on my truck.my questions are what would you recommend in a good but shorter spark plug to use with headers?any recommendations on a cheap but good cure to keep the spark plug wires off the headers?im open to suggestions but im also on a budget so MSD stuff is at the time out of the question.thanks guys
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
12-27-2002, 04:46 PM | #2 |
~THE SILVER BULLET~
the bosch platinum's i just bought were only 2 bucks each...i dont know about the length though. i dont think they were much of any shorter than the delco's it replaced
~1980 c10 chevy scottsdale~ ~2.5/4 drop 305/th350c~ |
12-27-2002, 05:39 PM | #3 |
I installed new plugs when I installed my headers and they are standard AC Delco ones. The length is fine on them. Any standard plug should work well. Sorry I can't help on the short ones.
Scott Shelbourne |
12-27-2002, 05:58 PM | #4 |
A/C makes a short plug but I believe it only comes in the platinum series (expensive). Accel also makes a shorty plug that's not too much $$ but not as widely available. Invest in some plug wire heat shielding if you think your going to be that close, but first put it all together & see if it's actually needed.
12-27-2002, 11:10 PM | #5 |
driving is in my blood
accel makes shorties, see em at checkers all the time. But I will never suggest an accel product to anyone.
As for in-exspensive wire holders, break out the safty wire bro. What do you need MSD stuff for just to hold wires? MSD wires stink in terms of durability too.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-27-2002, 11:24 PM | #6 | |
You get what you pay for
Mike 1985 Chevy C-10 |
12-28-2002, 01:42 AM | #7 |
I have had a set of MSD wires on my truck since august, and they are holding up fine. The only thing I didn't like about them, is I got the cut to fit ones, and to get the terminals to stay on the wire, you have to buy their $75 crimping pliers. I tried the thing that came with the wires, but it didn't work well enough for them not to just come apart after a while. But, other than that I reall like them, and I wouldn't think twice about buying another set.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
12-28-2002, 02:00 AM | #8 |
Larry,
I also have a set and wouldn't have any other wire. I used the little crimper/stripper tool that came in the set. Worked like a charm for me. Although, I do wish I had a set of their crimping pliers. They are nice indeed, but pricey as all get out. I may buy them one day just so I can say I have them. I was only picking at Tom about the stinking thing he said. I bet he's never even owned a set of MSD wires.
12-28-2002, 01:52 PM | #9 |
5 day ban, learn to behave.
i have a set of those spark plug boot boots that seem to be an asbestos material, on my truck. but you said inexpensive and unfortunately they cost about $80 or so for a set of 8. you can get them at Napa or in Summit racing. they are really nice though, thick, and do an xlnt job. Sometimes they are laying on the header and the wires dont burn. With a SBC w/ headers, I think you will always have a problem, due to the design and location of the spark plug and exhaust port
mike |
12-28-2002, 02:52 PM | #10 |
i have never had a problem with headers and plugs interfering with each other, i've been through 3 sets of FlowTech headers, a set of Dynomax, and the Edelbrock TEMS on my TA.
12-28-2002, 05:55 PM | #11 |
I don't have a problem either, but of course the Edelbrock TES headers don't lend to running the wires over the top like normal. The A.I.R. tubes are in the way for one thing, and the header design won't let you. I run my wires under the headers. I have to say it's one of the cleanest looking setups I've ever had.
12-28-2002, 06:34 PM | #12 |
Iamnotanofficerofthelaw
Just buy stock wires jeeez. :p Accels do suck btw.
~Paul~ '96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock '87 S-10 Ext Cab- 2.8L/700r4 KIA Caught fire 12/7/03 |
12-28-2002, 07:46 PM | #13 |
When I put the new motor in my 79 I did a tune up too, new plugs, cap, rotor, etc. but I ran out of money to replace the wires. So I pulled the big $$$$ MSD's off my 78 and put them on the 79. In my haste I missed the fact one wire was lying on the manifold. 2 days later I had a wire with no insulation what so ever. Several other that wernt touching the manifold were lossing the rubber too. I couldnt belive it.
Now Ive had two sets of borg-warner wires, and on both sets several wires have been touching the manifolds/headers. None of the wires ever went bad from the heat. They never lost their insulation. They will get a small black spot, but remain bendable and un broken. Thats all I needed to concinve me. To add to all that, one of the guys on CT posted a topic a while back. He bought several sets of wires and tested them at home. The accel wires were absolute junk [in terms of conductivity at least] the MSD's were good, but the cheapo borg-warners were at the top.
12-28-2002, 08:01 PM | #14 |
Well, IMO, it's not good to have a wire touching anything hot. If you can't keep them off the header, they will burn.
I'll keep my wires off my headers and also keep my MSD's, although they may be inferior to the Borg-Warners. I say run whatever makes you happy.
12-28-2002, 08:02 PM | #15 |
Oh, and I do agree with you on one thing at least. The Accel wires are junk.
