the pollock
seriously i had too much fun this week with my truck...
when sitting (or moving slowly) the PS feels "jerky"... going to lift up the frint end this weekend and check the PS components.. any reccomendations? might take off the motor itself and see if it's trashed inside.. any ideas?
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
profeshinaly unimployed
Re: think i broke my ps..
hey man check that out for me too my trucks done that since i got it
"having mud flaps is like asking for a smaller trophy" |
Size Matters
Is the fluid level OK?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
the pollock
yes fuid is good.
and there's no "whine" when i steer... it just feels "jumpy" perfectly smooth then jumpy again.
Nobody rides free
![]() Join Date: May 2005
Maybe a tooth broken on your steer gear?
Or a whooped rag joint that's got slop & binds up? Those are just my 2 best guesses, I have no idea. ![]()
'71 C10 LWB 400SB/350TH ![]() '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
Size Matters
How 'bout belt tension? Also what were you doing last weekend that might have damaged the PS? If you were "4 wheelin" you may have bent some suspension components that might make it feel funny.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() Last edited by Longhorn321; 04-30-2009 at 09:51 AM. |
Could be a belt slipping, check for very shinny underside of the belt. If it is super shinny I would buy a new belt.
.02c
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
check ball joints, especially for grease.
Eric |
the pollock
whooped rag joint????
Nobody rides free
it's the weird looking 'joint' in your steering shaft...don't know how to describe it, looks like a disk in the shaft. 'whooped' as in not completely busted, but having play in it.
pic in this post is a rag joint http://67-72chevytrucks.com/vboard/s...d.php?t=244273 and another rag joint thread http://67-72chevytrucks.com/vboard/s....php?p=3226408
'71 C10 LWB 400SB/350TH ![]() '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young Last edited by bowtier; 04-30-2009 at 12:58 PM. Reason: 2 linky's |
the pollock
ok yall
doublechecked the fluid level and re tightened the belt ( how it squeals when i do this) then i bring the steering more than 1/3 out to the left (from center) or to the right (from center) the pump does the same crap still soooo! i got under the hood and moved the shaft by hand to make the tires go left and right and watched the pump pulley slow down... BUT it only does it at that one moment.. after that 1/3 either direction from center it hitches and then works fine..... is my ps pump wearing out? OR should i pull off the steering stabalizers to see if it still does it
the pollock
ok still squealing, and i feel not so good about my truck today..
it is doin still as the described above, have friend turn wheel and you can see the pump wheel slow dramatically ( i painted a small white line so i could have a visualization for wheel speed) what should i do? i was thinking about opening the lines.. draining the fluids out.. and checking every thing out basically any input or ideas?
dammitmitchell
If you decide that you need to get your box repaired http://www.powersteering.com/ I met them at a local swap meet several years back They seem to specialize in pumps and know them very well.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
#14 | |
If the pump "slows" but the rest of the engine does not.....the belt is still slipping, whether it makes any noise or not.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
