Old 05-01-2009, 01:54 PM   #1
ashx2
Question Engine rebuild......350
I'm looking at rebuilding an engine for my '72. I'm going to send the block to a company and have it all prettied up and prepared for the rebuild.
I have been told that I should get some TBI heads, and that I can buy a rebuild "kit" and it would not cost me near as much as if I went out and bought all the goodies individually.
Is this correct? And what's so great about TBI heads? I'm not looking to build something to race with, just something solid/dependable to drive for the next many many years to com.
Opinions?
Thanks,
Greg
ashx2 is offline   Reply With Quote
Old 05-01-2009, 02:10 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Engine rebuild......350
I've heard that TBI heads don't flow very well. Try some Vortecs.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-01-2009, 02:28 PM   #3
jbristo67
resident oilfield trash
jbristo67's Avatar
Vortecs for sure
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-01-2009, 02:50 PM   #4
big_al_71
big_al_71's Avatar
I would go with edelbrock aluminum heads but thats just my opinion. I have heard about the vortec heads as well.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-01-2009, 03:39 PM   #5
monte0185
monte0185's Avatar
I rebuilt my 307 with a set of vortecs. I put a mild 267/277 cam in it and those heads and its 30 over and it really wakened it up.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 05-02-2009, 05:10 AM   #6
jim zag
ENGINE BUILDER
jim zag's Avatar
What do you want? Performance? Economy? You need a PLAN!!!! Are you on a BUDGET? How much do you have to spend? TBI heads are easy to find but require a specific intake because the center bolts are a different angle. VORTEC heads flow a lot of air and make great POWER! They require specific rockers, valve covers and intake and a different alternator mount. Build a 383 stroker!
JIM ZAG
jim zag is offline   Reply With Quote
Old 05-02-2009, 11:33 AM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
If you have no experience building an engine or the proper tools, it will probably be cheaper and more dependable to buy a rebuilt plain jane 350. A rebuild using the original pistons and not doing any head rebuild or valve job will cost at least $450 to 500. If the bores are taper and it needs bored out, add about $100 for basic machining and another $200 for pistons (they need to be pressed onto the rods also. A valve job will probably cost another $150-200. This is assuming you don't have any other problems with any of the parts, and re-use valves, push rods, intake, front cover, oil pan, dipstick, etc.
I rebuilt a shortblock last month as cheaply as possible, and I'm re-using the heads and intake as is. I have all the required tools and spent about $450. I've done it a few times before, and I'm still hoping I didn't mess something up. I'm still running the 283 I built about 20 years ago, so I have reason to believe I did OK.
There is lots of help and info available if you decide to do it. It's not that hard mechanically, just a lot of tedious measuring and fitting and cleaning, etc. Good luck, it's kind of full-filling knowing I did it myself.
hgs_notes is offline   Reply With Quote
Old 05-02-2009, 11:47 AM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
nothing is 'great' about TBI heads. they do make a great door stop though. A stock casting from 70-84ish will be your most economical (traditional intake & valvetrain parts), the vortecs offer great hp/$ but as stated above, require specific valvetrain parts and intake.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
