05-03-2009, 11:48 PM | #1 |
60-66 Nut
Clevite Bearings
I've been looking at the Clevite "H" series bearings for a 406 that my son and I are building. This engine will be run hard on and off the track, and with a 150 shot of N2O. Are the "H" series bearings worth the money , and will they hold up better to the added pressure of a N2O shot?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-03-2009 at 11:49 PM. |
05-04-2009, 08:53 AM | #2 |
Re: Clevite Bearings
They work great,they are chamfered,so make sure your crank is chamfered too.
05-04-2009, 10:45 AM | #3 |
On a budget like Fred Sanford
I run Clevite H bearings in my camaro's nitrous motor. I'd definitely run a coated bearing with your plans.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
05-04-2009, 12:58 PM | #4 |
Registered Truck Offender
My machinist ( drag boat and offshore motor builder) talked me into switching to King engine bearings a couple of years ago. I swear by them now. After 2 seasons of hard racing (about 160 passes per season) the crank and bearings still look great in my Nova. ( 790HP small block) Leakdown is starting to come up little now. But when bearings outlast a set of plasma-moly rings,,, they are a GOOD race bearing.
just my 2cents
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
05-04-2009, 11:41 PM | #5 | |||
60-66 Nut
Thanks for the replies guys.
Another related question......would it be advisable to run a high pressure oil pump on this engine, or would a standard pressure pump provide sufficient oiling. I imagine it would depend on the bearing clearance. I'm not sure what clearance the machinist ground the crank for......I'll have to call him tomorrow. And yes I will be checking the clearance once I get some bearings.
05-05-2009, 08:45 AM | #6 |
If/When you get the crank journals turned,the machinist can grind in the radius.
05-05-2009, 09:12 AM | #7 |
I have had the King's and the H-series Clevites start flaking under heavy loads. 14-1 sbc dirt track engines turning 82-8500rpm's. We had the Kings in a blown BBC with 32lbs of boost, and they were showing signs of flaking after 10 passes. I've been running the ACL race bearings, and they seem to be the best I've used. i've also used the Tri-Armor Clevites. They seem to be a good bearing as well.
As far as all this goes I ran a 355 with solid lift cam and Dart heads for 2 years on the street with a 200 shot. Plain Jane old p bearings in it, and it was fine. After all that abuse they showed a little wear but weren't bad. |
05-05-2009, 10:33 PM | #8 |
60-66 Nut
Crank is already turned.......
05-06-2009, 11:12 PM | #9 |
60-66 Nut
So you guys that are using King bearings, which ones are you using.
the AM, CP, or HP bearings? And who has the best prices on them? Thanks
05-07-2009, 11:45 AM | #10 |
It depends on the application. I've been using the HP's in my Nova motor, but it's a dedicated track only machine not ANY street time. And make SURE you have to have the right radius on the journal for bearing you choose. No guessing.
machstick,, have you seen similar problems with a drag motor where the high rpm's are only sustained for 9 or 10 seconds? Just curious. A dirt track motor definately is the ultimate for rotating assembly abuse. I shift my 434 sbc at 7400 (13.5:1 n/a) and have not seen any hint of a problem with the bearings.... 'yet' . Been running the King bearings for 2 seasons now and will definately keep a eye on them.
05-07-2009, 11:59 AM | #11 | |
