20's on a step side???
I am wanting to get 20" wheels for my truck. It is a 68 short box step side. It is on dominators and 2.5" drop spindles with a c-notched frame. I phoned Coys and talked to them and they said that a 20x8.5" with a 4.75" backspacing with be best. Does any of the stepside guys have pics of their 20's on their truck. Looking for ideas on what to put on it too..
Do you guys think I will have any problems fitting them in there... I seached, but didn't really come up with anything.. Thanx guys..
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: 20's on a step side???
8.5" wide x 4.75" offset sounds feasible. standard offset would be around 4.5" for 7-8" rims. they would be close, but I think you'd be able to tuck them in nicely without cutting the bed.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 05-04-2009 at 12:41 PM. |
resident oilfield trash
Check this out this is the sweetest stepper I have ever seen http://www.67-72chevytrucks.com/vboa...d.php?t=332337
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
WOW, that is sweet. That is the look I am looking for. 20x10 sounds like an idea. Going to look into that build and see what suspension mods he has..
What do you guys think about Boss wheels. I like the 329, 335, and the new 338.
I would go 20 by 8 in the front that guy has to air his bags all the way up to turn. Just my .02
#7 | |
PITbut
I don't think it is a stock width rear-end in that truck either ... a 10 wide rear on a step side is gonna be very hard pressed not to rub.
Damage Inc
Thanks for checking out my build guys. Yes u can run 20 by 10s in the front the reason its hard for me, is i made custom inner fenders and i made them a lil closer that expected so it rubs if turn all the way but i can still turn with the bags deflated. My rear end is stock i got the maximum lip i could get with out having to cut the rear end and still tuck. the only thing is you will have to cut or shave off the inner fender lip. not a big deal.
Do you have a closer pic of the rears and how you shaved the lip on the outer fender. Do you have a panhard bar to keep the diff from shifting and the tires from hitting. How big is your c-notch aswell.
I am leaning towards the Boss 329's
Damage Inc
I have some close pics of the rear on my build page. yes i have a panhard bar. and i have a mild c-notch. didnt want to cut up the wood bed
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
#12 | |
#13 | |
whats the back spacing on those wheels and what size tires(front and rear)? great truck! Last edited by Shane; 05-05-2009 at 12:33 PM. |
Damage Inc
Not really sure..ill have to double check but the rear has a 5 1/2 inch lip and the front has a 3 1/2. THe tires are 275/35/20 all around
#15 |
I am still trying to figure out something for wheels and would really like to have a 20x10 in the rear
Trenz68 could you please share the back spacing and offset of your wheels... any suggestions on wheels would help aswell... Thanx Trevor
#16 |
nice tucks
cucharitas customs |
#17 |
I just got my 20" coys a few weeks back with 4.75 b.s all round, mine is on a different frame than yours (a bit narrower) fills out nice up front you would need to do some measuring before you order
#18 |
Ausmarty, I like those Coys... Are you running air or just static drop...
#19 |
I'm Using a frame from a GM Aussie made Holden ute, The front is on the bumpstops but it is about where it will end up with drop stubs and low coils, the rear is lowered leaf spring and 1.5" blocks
#20 |
|There is only 11 1/2" in the rear fender. It will be tight and with the rear axle moving from ride height to full dump it is going to rub or hit...
Is it easy to tube a sideside??? Trevor
