C-Notch Question
I will just give some background info. I am new to resto jobs. 2 yrs ago I bought a '67 C-10 SWB, it was 50% done. Engine and trany were done and the truck had been lowered. But the rest of the truck I got in pieces.
Since I bought it I had it painted and have slowly put it back together. I is finally finished and ready to drive. Since I have never insured it before I need an inspection done. Took it in and the inspector failed it on a number of things, however the most worisome to me is that he says the c-notch was not done properly. He said that the frame needs to be boxed around the c-notch which mine isnt. It was just cut out and a piece of c shaped steel was welded in. Unfortunately I don't have picutures right now. Do you think this would be strong enough or do I need to box in the c-notch. The garage that did the inspection is a resto shop and I want to make sure thay are not trying to make some money on me. Also the rear suspension was converted to leaf spring instead of the stock coils. |
Between Trucks...
Re: C-Notch Question
I've seen a lot of trucks done that way. Don't know what the requirements are in Canada though.
Beat it to fit, Paint it to match... ![]() |
Nothing to see here.....
![]() Join Date: Jun 2007
get a second opinion. sounds like b.s. to me...
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 05-05-2009 at 12:36 PM. |
Check w/the shop to see if a bolt-in c-notch would 'pass'. The bolt-in style notches are 1/4" plate doubled against the sides & bottoms of the original frame & secured w/GRADE-8 hardware.
If they say yes, & you want to DIY, cut the old c-sections out & bolt in the new ones. If they still won't pass this style of notch, get a second opinion. If the opinions are consistent, have one of the 2 shops do the work or box it yourself (boxing it should be more than sufficent).
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
resident oilfield trash
They are trying to make money off of you. Take it some where else
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Maybe they are, maybe they aren't. Regulations are different there vs. TX. A second opinion will help make an educated decision vs. assuming or guessing.
