05-05-2009, 11:36 PM | #1 |
suspension questions
I've had bagged trucks in the past. I don't wish to bagged my c10. What is the lowest that I could possibly go? I also want disc brakes on all four corners. Should I go with a bigger rotor and caliper? I'm running a 20x8 in front and 20x10 maybe 12 depending on motor/rear end situation. I plan on running a LS1 motor. Would that effect how low I can go?
05-06-2009, 12:23 AM | #2 |
Happy to be here
Re: suspension questions
What year truck ya got?
05-06-2009, 06:53 AM | #3 |
05-06-2009, 08:18 AM | #4 |
Tot Roddin'
In my opinion...
If you are wanting to run a larger dia. wheel (20" as you mentioned), I don't think you will be able to go any lower than a 4.5/6" drop without running into issues with turning radius up front. This will allow adequate room for turning and also allow you to retain the inner fenders and no major modification. You can run a bolt in c-notch if you need the extra room in the rear but it is not required. Now if you would want to go all out there's z-ing a frame but it doesn't sound like you want to go that far into the project. And as far as I know changing to an LS motor will not affect how low you can go. If you have the money, upgrading the brakes would be nice, but not required. As long as the brake system is fully operational, you shouldn't run into any issues with running a stock brake setup with a larger dia. wheel/tire combo. One thing you will need to take into consideration is the 6 lug to 5 lug swap and also the rearend difference as well. IIRC the 67-70 (early) models had a narrower rearend than the 70 (late)-72 rearends. This will affect your backspacing, so if it were me, I would have the suspension set and then measure for the wheel setup. Just my $.02... but I hope this helps.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 05-06-2009 at 08:19 AM. |
05-07-2009, 09:59 PM | #5 |
05-08-2009, 12:51 PM | #6 |
05-08-2009, 01:59 PM | #7 |
Resistance is Futile
I'm at 5.5'' in front with a 26'' tire...static drop. I think I figured up that if I was running 20's I would have to run a 245/35/20 for my 64. Im not sure about clearance on the later trucks.
The kit you linked would do the job...just specify a 2'' or 3'' spring in front.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-10-2009, 03:22 PM | #8 |
what would be a good kit? From what i've seen. I will have to purchase several components. I would like a 4/6 with front/rear disc
05-10-2009, 09:04 PM | #9 |
Tot Roddin'
I would recommend Early Classic Enterprises (ECE). They offer some of the best products and customer service that is next to none.
I haven't personally ordered from CPP but if you check out the review section of the board several board members have ran into difficulties with them. Also... depending on the brake setup you want to run, you could technically run a manual disc-drum (if wanting to save money) and still run 20's. And, depending on the wheels you choose you might even be able to stick with the 6-lug setup. Just my $.02... (again)
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-10-2009, 09:41 PM | #10 |
Or you could contact one of our board vendors and give him a shot at your business ... you know, supporting the board and all.
05-12-2009, 06:42 PM | #11 |
IV. Pure trolling, either to upset someone or simply for your personal enjoyment, is strictly prohibited. If you're here to cause trouble, it will be a very short stay.
Immediate BAN and you will be reported to your ISP. That's twice in one day. Last edited by Shane; 05-12-2009 at 07:46 PM. |
05-13-2009, 06:47 PM | #12 |
Tot Roddin'
Right on Shane... about the supporting vendors, always check there first. IIRC, several of the board vendors even supply ECE products.
05-13-2009, 10:14 PM | #13 |
Remember, w/a 20" front wheel, you're likely going to be @ 27.75" minimum w/any decent sidewall (that's a 245-40-20 min). So a 4/6 static drop will work just fine. I do feel the 12" stock rotor looks small vs. the window of a 20" wheel so stepping up is a good idea mechanically & asthetically. The rear drums are already about 13" OD so they don't look 'lost' & can be left as is to help the budget. If there's room in the budget for matching 13" rears, do it.
As mentioned, our board supporting vendors do deserve our business if/when possible.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-13-2009 at 10:18 PM. |
