Gear oil
What weight / type gear oil should I run in my new axles?
14bff rear with factory eaton gov-lock? D60 open front? Thanks -RMK
71 ![]() |
![]() Join Date: Feb 2000
Re: Gear oil
I always use 80W90 in my axles, manual tranny and transfer case.
I'll let some one who knows advise if the gov-lock needs an additive - I don't believe it does, but someone will know for sure.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: Gear oil
Interesting because when i did the Front 60 and rear sterling 10.5 in my superduty the manual called for 70w90 in front and 70w140 in the rear, or something to that effect.
I remember I didnt have to use the slip additive in rear due to the open diff. but it called for so many ounces of something if it had a posi.
71 ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Gear oil
I run synthetic 75W-90, D44 front and Eaton rear. Always thought 140 was only required in trucks larger than pickups...
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Chevys Kick A$$
Re: Gear oil
Ya x2 Gotta agree!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: Gear oil
In my old chevys I run 80-90 throughout
In my dodge I run 80-90 in the front and t-case with a healthy dose of Lucas the rear has 85-140 lucas extreme service lube
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
Re: Gear oil
80w90 in the 60/14 and 205
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
Re: Gear oil
Dito!
Additive should be use when you have a Posi or limited slip w/clutches ![]() I use to run Dana Powr-Lok and they required the 4oz shot of additive, I love the smell! makes me think of metal shop and my testosterone levels rise hahahaaa ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Re: Gear oil
Thanks gentlemen, info is appreciated.
71 ![]() |
Re: Gear oil
Synthetic for cold country pumpability and lower wear and tear on the bearing and gear teeth mating surfaces.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
