Old 05-07-2009, 07:58 PM   #1
custom63
custom63's Avatar
73-87 Control arm Bushing Replacement
I have 1980 doner upper and lower control arms for my '63 build and I want to replace the worn out rubber bushings. Can someone clue me in on how to properly remove the old ones from the arms and shafts and how to install the new ones? Ive done a search and have looked over the FAQ section and have only found info on the older non-rubber versions. Pics of the process if possible would of course be awesome!
Thanks in advance!
Tommy~
The difference between genius and stupidity is that genius has its limits
-- Albert Einstein
63 build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317341
custom63 is offline   Reply With Quote
Old 05-08-2009, 08:31 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 73-87 Control arm Bushing Replacement
I watched my bro-inlaw who is a master mechanic do a set. He whipped out the cutting torch and burned the rubber out. It made a nasty smoky mess, but was done in a few minutes.
He put the new bushings in the freezer for a few hours. After he cleaned up the control arms, they pressed right in with a hydraulic press.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-08-2009, 10:36 AM   #3
Tagg33
Tagg33's Avatar
I went to Checker Auto about a month ago to rent a ball joint separator kit and they accidentally gave me a different kit that was for removing the bushings. I recongnized it because I recently watched someone use the exact tool to remove my dad's 99 GMC Yukon bushings at a shop. Its like a heavy duty C clamp that uses off set spacers to press out the bushing and all you have to use is an impact wrench to tighten the C clamp far enough to press the bushing out. I hope that made sense but the idea is you can go to a Checker/Kragen Auto type store and rent/borrow the tool to extract them. The hard part is pressing them back in. The shop used a hydraulic press to put the new ones in.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 05-08-2009, 11:15 AM   #4
custom63
custom63's Avatar
Thanks for the info guys. Now I just have to decide which route.....Burn 'em or clamp 'em. I'll keep ya posted on the progress.
Tommy~
-- Albert Einstein
63 build Thread
Old 05-08-2009, 03:11 PM   #5
sandfreek
Be sure to chisle the lip in on the inside where they bent it out from the factory...Once you have done that you can pound them out with a chisle and big hammer...I just did mine that way because im too cheep to have it done...To press in I used a socket that fits the outer edge and pounded them home...it takes a little while but saves a 100 bucks, thats what 3 shops quoted me to do it...
sandfreek is offline   Reply With Quote
Old 05-09-2009, 01:51 AM   #6
jpz63fleetside
i did mine the burn out and hammer way on 2 of them, then my neighbor saw what i was doing and brought over his bushing tool that looks like a C clamp. the torching them way makes a huge mess and IMO is better to go rent or borrow the right tool for the job.
jpz63fleetside is offline   Reply With Quote
Old 05-09-2009, 06:10 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's coincidental, I am using an 80 model donor to build my 63 with also.
I used my press to push the old ones out and the new ones in. I spent a lot of time cleaning, prepping, and powdercoating the arms and shafts and hardware, so I wanted to put them in without involving hammers or torches.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-30-2009, 11:02 PM   #8
1986swb
1986swb's Avatar
Yes, they look great Kevin. I am in the process of changing out both upper and lower control arm bushings for my 1986 GMC 1/2 ton. I would like to get your (and others) opinion on whether to go with traditional rubber or polyurethane bushings as replacements. I like the increased control the polys provide but I hate all that darn squeeking. Do poly control arm bushings squeek as much as poly sway bar bushings? I would appreciate your pros and cons insights for both rubber and polys. Thanks.
1986swb is offline   Reply With Quote
Old 05-09-2009, 01:37 PM   #9
Custom 68
Custom 68's Avatar
wow Kevin, those loook great.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-09-2009, 05:53 PM   #10
Tx Firefighter
I appreciate the comment. It takes a ton of time and work to go from dirt and grease caked to looking like that.
Old 05-11-2009, 12:37 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I used my press to remove and reinstall mine as well.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-30-2009, 11:05 PM   #12
smashingchuck
With the poly's I drilled holes throught the bushings and sleeves so everything will get grease that want's it. Not sure if this will fix it though... the squeeking drives me nuts!
78 Build Thread
4Runner Build
