Passanger side window regulator
My passanger side window is hard to move up or down. there away to oil it?
I am a Referee of life.
Re: Passanger side window regulator
Take the door panel off.You will probably have to feel around in there to find the rollers and track they run in.I usually lube them with white(lithium) grease.I also spray the window run channels with a silicone lube that helps the glass slide in the runs.While there you may want to spray the window regulator gears and bearings.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thanks - I found some spray on white(lithium) grease at Lowe's . that door is well oiled.
