How much nitrous can I safely run?
I have a 4 bolt main 350, stainless steel crank (I can't find any info on stainless cranks, but thats what the machine shop told me I had), 302 chevy (pink) rods and speed pro forged aluminum pistons. How much do you think my bottom end can handle? I don't have arp bolts but will once I put the no2 on it. Good rods aren't too expensive these days so I will probably get new ones just to be safe (any recomendations?). But I really can't afford a $1,000+ crank right now. I am hoping a cast stainless crank is better enough than a plain cast steel crank to handle at least a 150 shot if not a 200. Maybe you guys can tell me what I've got by looking at this picture...
![]() as usual, any help is greatly appreciated! oh btw, when I get home I think I have a few more pictures of the crank that are high def if they are needed
1969 C-10 Short Bed Last edited by BrentRS1985; 05-10-2009 at 05:08 PM. |
Redefining LowBudget
Re: How much nitrous can I safely run?
wet system or dry???
if wet let it have it I would start with 150 do a run and shut it down to do a plug check for a lean condition then adjust accordingly....I run 150 on my V8 s10 and it's on dot slicks with an auto and its only a 2 bolt....but I have run as much as 225 on a hot day to keep me in the 12.99 bracket
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#3 | |
I'm probably worrying about nothing, I know a guy that has over 75 passes on a stock bottom end ls1 running a 300 shot. Although the ls1 is a 6 bolt main, its aluminum.
1969 C-10 Short Bed Last edited by BrentRS1985; 05-10-2009 at 05:24 PM. |
stock cast
stock the shift light comes on at 6800 but it has been held till the vavles flutter many many times and I don't look!!! what the perpose of doing it ?/ are you racing or just using it for a teaser??? also how much HP are you making with out it??? going from 200 hp to 300 is one thing going from 350 to 500 is another
On a budget like Fred Sanford
How much power N/A? What are your rings gapped to? I personally wouldn't spray more than 200 on a cast crank. Gap the rings right, run the right plugs and pull enough timing and you should be fine with 150-200.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
I haven't had it on the dyno but I'm guessing around the 400 range at the crank. I'm honestly not sure what my rings are gapped to, can I find this out when I remove the heads (I want to find out how much valve clearance I have before choosing a nitrous cam). I'm wanting to race it, but it will be mostly street driven. I won't be on the bottle very often.
1969 C-10 Short Bed |
Registered Truck Offender
Everyone has a recipie,, I was dumping a 225 shot at a cast crank, stock rods and a set of good TRW forged (L2304f) LT1 clones. I burned through a couple hundred pounds of N2o and 7200 rpm shifts and the worst thing that happened was melted the tip off a couple of plugs. Follow the rules and you should be OK but it's ALWAYS a gamble.
Once you have a solid baseline for your motor unboosted, here is some very conservative guidelines For every 50HP of N2o reduce timing 2 degrees For every 100HP of n2o add 10 octane points to the fuel you run,,MOTOR OCTANE, not R+M/2 or anything else, research the MOTOR OCTANE of the fuel your using. Increase fuel pressure 1.5 to 2psi for every 100HP of n2o. Run 1 heat range colder plug for every 75HP you add with N2o. Follow those general starting point guidelines and your motor should survive IF it is in good condition to start with. I think I have a page with motor octane listed for many of the more popular brands of race fuel.... I'll see if I can't find it and edit a link in here.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 05-25-2009 at 01:38 PM. |
Oh,, bTW, "stainless steel crank" ???that's an interesting one!!! I don't think so. Someone ws mis-informed or misunderstood. Stainless is really not that strong, it just polishes up pretty and resists stains and rust AS LONG AS it isn't in direct contact with more ferric metals.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 05-25-2009 at 05:09 PM. |
