Old 12-29-2002, 06:26 PM   #1
special70gmc
special70gmc's Avatar
Talking removed the leafs
i finally got around to the rear end of the truck today i ran new brake lines dropped the rear end and removed 3 of the 6 leafs from the leaf springs i figure it dropped about 4 inches i got big tires on there now so it doesnt look as good asa id like but its an improvemento yeah thanks crazy longhorn for answering all my questions
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-29-2002, 06:28 PM   #2
special70gmc
before pic
1958 belair 2door
Old 12-29-2002, 06:29 PM   #3
special70gmc
another
1958 belair 2door
Old 12-29-2002, 06:33 PM   #4
special70gmc
last
1958 belair 2door
Old 12-29-2002, 10:36 PM   #5
Chevy Punk
I have the same suspension and I want to do the same. Did you take out the overload leaf? How does it ride and how do you think the load capacity will be? Which leaves did you take out?
Chevy Punk is offline   Reply With Quote
Old 12-29-2002, 10:41 PM   #6
lofly'a
lofly'a's Avatar
that's a great move to adjust the height, and if you need to increase load capacity, slap in some air bag helper springs. they are setup to bolt to the top of the leaves and work great to improve the ride and capacity.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-30-2002, 04:19 PM   #7
GloryHound
Working on a Nova.
GloryHound's Avatar
Hey three of the four leafs on each side of my truck are broken and that is about the ride height I have! Hmmmm I bet your method is a little safer though than riding around on broken leafs!!!
GloryHound is offline   Reply With Quote
Old 12-30-2002, 07:54 PM   #8
special70gmc
i left the overload in it. also its got no shocks yet and its not on the road so i cant drive it
1958 belair 2door
Old 12-30-2002, 08:56 PM   #9
Chevy Punk
Do the other springs ride on the overload causing the ride to be rough?
Old 12-30-2002, 09:19 PM   #10
crazy longhorn
Fabricate till you "puke"
Im runnin 4 leafs on the longhorn......tossed the helper, & 3 leafs. The old truck rides nice......but not a hauler(2 3/4" tween the frame & axle......no bump stops). I also had to add a set of slapper bars to handle the wheel hop. I wouldnt think the helper spring would make it any stiffer , till its loaded.......or hit a mean pothole(I hate potholes, they grow like toadstools in Ill!)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
