05-13-2009, 10:43 AM | #1 |
Column shifter loose
What are the possible causes or solutions for my really loose column shifter (TH350 auto).
It can slide from R-N-D way too easy. Almost slip out of D while driving.
-- Tall, Dark and Handsome... Or so my mother says -- There is no fate, but the fate we make. |
05-13-2009, 12:37 PM | #2 |
Re: Column shifter loose
Anyone?
05-13-2009, 01:50 PM | #3 |
So a buddy of mine brought up it might be the "detents" on the transmission?
Any thoughts?
05-13-2009, 04:30 PM | #4 |
From neutral to dr. dr2 & low are pretty much in the trans. The selector has lock outs for park & r down on the lower part of the column. Sometimes the up & down movement of the tube inside the column gets sticky or stuck & wont let it drop in or is hard to raise to shift.
05-13-2009, 07:43 PM | #5 |
its all about the +6 inches
in a non tilt column, it is more likely than not, the shifter.
As mentioned, the tube sticks and binds, and it won't freely fall into the detents on the column. Its a very crappy design. You can take it apart and rebuild it, or swap it out for a tilt that has a much better set up... and the tilt. Truck tilts are a little expensive, and van ones can be stupid cheap, but take a few small mods to make them work |
05-13-2009, 11:45 PM | #6 |
Thanks for the input.
10-21-2009, 01:35 PM | #7 | |
10-21-2009, 01:47 PM | #8 |
a cheap thing to try is just spray the crap out of every moving part you can see or reach with a can of WD40 // sometimes just clearing out that 40 year accumulation will help
05-14-2009, 09:50 AM | #9 |
There is a little rubber grommet on the end of the shifter lever - Mine was real sloppy and when I pulled the shifter lever, it was missing - replace that rubber piece and it makes a huge difference.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
05-14-2009, 03:38 PM | #10 |
Restoration Virgin!
Hey Dan42....Good Info....Where did you get the rubber grommet??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-14-2009, 10:52 AM | #11 |
Thanks Dan, hopefully its the easy fix
10-21-2009, 02:24 PM | #12 |
PROJECT 7DEUCE
Mine was just frozen and i used the wd-40 trick too bad the bearings are all wore out..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-21-2009, 03:16 PM | #13 |
what about the plastic bushing on the end of the shift lever? anyone know if this is readily available at auto parts stores?
10-21-2009, 04:39 PM | #14 |
I just went through the same process with mine. I took the shift linkage apart and re-assembled it. The rubber piece was shot so I put in an exhaust hanger grommet and that shored it up pretty good. There are a couple of small springs attached to the linkage and you can either attempt to stretch them out or put stronger ones in. This helped alot but the rest of the problem lies within my forty year old never been re-built turbo 350.
11-25-2016, 11:15 AM | #15 |
I've looked on here, but can't seem to locate answer I need so I'll ask here...I know it's an old thread and I apologize...
...my column shifter doesn't seem to line up in park where my truck will start...I keep having to move it back and forth in Park position to get it in right position before it'll start... again I'm sorry and thanks, Keith |
11-25-2016, 11:47 AM | #16 |
Slowboy sounds like you NSS (NUETRAL SAFETY SWITCH) may need adjusted or replaced . It is on the lower part of steering colum held in by a couple screws that allow you some adjustment .
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-27-2016, 09:45 AM | #17 |
thanks for reply Kaycee...do you have a picture of this switch's exact location?...
I looked and didn't seem to see it...I did see that an apparent bushing is gone at the [shift adjustment rod, at the top of column under the hood... made a bushing from a piece of bronze I/2" x 5/8" x .340" ...it took most of the sloop out of shifter, but still seems to need a little adjustment to be on NSS 'sweet-spot' when in 'Park'...how can I adjust this please?...I still have to raise up on column shifter sometimes when I start my truck...not a lot, but some, sometimes...thank you |
11-27-2016, 09:46 AM | #18 |
" slop " not " sloop "
11-27-2016, 03:56 PM | #19 |
This is close to how it looks it is inside cab by firewall on the steering tube
https://www.opgi-static.com/common/9779665-lrg.jpg
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 11-27-2016 at 04:04 PM. Reason: DELETE |
11-27-2016, 03:59 PM | #20 |
Does this work ? bear with me on this freeking computer
http://67-72chevytrucks.com/vboard/a...1&d=1403060355
11-27-2016, 05:36 PM | #21 |
Mine was stiff, and the cab shift lever did not want to "drop" down, so I got a can of the Silicone lube WD 40, which is supposed to be safe for rubber, and really sprayed the heck out of the shift lever pivot, and down into the sleeve from all sides. I used a rag to catch the extra. I also sprayed the mechanism under the hood, and the results were really good. The detents are distinct now, and the lever drops down into the detents when you let it go.
I still have a problem that I sometimes have to move the lever a bit past "D" (to the right) when I'm shifting from N to D. I'm sure there is an adjustment on the linkage under the hood, and when the weather is better, I'm going to get out there and figure it out. And hey! Now I have that happy WD-40 smell in the cab...
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
