05-13-2009, 07:08 PM | #1 |
modifying 4.8 vortec wire harness need help.......
Dropping the motor in my 67 already, got told I need to modify thee wire harness but clueless on wat to do anyone have a diagram or can tell me exactly wat to do...
05-13-2009, 08:37 PM | #2 |
J'ville Junkman
Re: modifying 4.8 vortec wire harness need help.......
Go check out LS1tech website, I understand you can get everything you need there. There is also a good writeup in the FAQ that mentions the wiring stuff. It might be called a 5.3 swap on the cheap or something.
Goodluck.
72 3/4t Suburban 402BB (Daily driver for 8 years) 68 GTO (never ending proj) 91 Kawasaki ZX-7R 57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans) 73 Corvette (17 yr old daughter's: Another project - what's wrong with me?) 53 Willys M38 |
05-13-2009, 09:08 PM | #3 |
I went to lt1swap.com and got the pinouts for my harness, ive printed them out and went down each pin to see if i needed it or not
05-14-2009, 12:59 PM | #4 |
the boat guy
wait 4 me performance will hack up your harness and tune with free unlimited retunes for $360. i sent mine off yesterday. they eliminate the vats, not just some added box like most.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, Last edited by brad_man_72; 05-14-2009 at 12:59 PM. |
05-14-2009, 02:05 PM | #5 |
cool thanks hopefully i get it done pretty quick i want the truck running already... what do yall plan on doing about the gauges, can we use the new a/c system?
05-14-2009, 09:22 PM | #6 |
05-14-2009, 09:49 PM | #7 |
the boat guy
gauges, you have to have the comp reprogrammed to sent out a v-8 tach signal, you can drill and tap plate above oil filter to make oil gauge work, rt head near the rear their is a plug you can remove redrill and tap for temp sending unit.
if using a transmission that doesnt have a speedo cable you need an eletronic speedometer (definatly cheapest and easiest fix, but not the only way to do this) im putting an eletronic speedo behind my factory gauge face and needle. im thinking a 94ish s-10 speedo will "work"
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
05-14-2009, 10:16 PM | #8 |
05-15-2009, 01:48 PM | #9 |
the boat guy
ill be sure to take lots of pics, and if i get it to work ill post up a how to. i think i heard about somebody else on the board doing something simmilar.
05-14-2009, 11:17 PM | #10 |
also most aftermarket tachs have a switch/s to make the tach read 4/6/8 cyl. you can simply put the tach into 4cyl. mode and it'll read accurate, w/out changeing the tach output of the PCM.
05-16-2009, 12:15 AM | #11 |
Another option for the oil pressure gauge is to just use the stock hole behind the manifold. The PCM doesn't need the stock sending unit signal. Adapter bungs are also available for the temp sensor if you don't want to drill and tap.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
07-27-2010, 08:32 PM | #12 |
Addicted to Rust
You have to make an adapter though the LS oil sender seals with a gasket and straight metric thread the "truck" sender will be pipe.
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
07-27-2010, 09:40 PM | #13 |
Next project: 1970 K10
Although it's an older thread, I'm gonna move it to the LS swap area.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
