05-14-2009, 01:38 PM | #1 |
Muncie m22 4 speed
I have a m22 muncie ive been thinking about putting in my truck a 69 c10 it has a 3 on the tree right now im just wandering how i would go about hooking up the clutch linkage. i dont know if there is a kit out there or if the linkage in it will work or if i have to fab something up.
05-14-2009, 01:54 PM | #2 |
Re: Muncie m22 4 speed
3 speed linkage works... No fab work needed.. At least on my 68
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
05-14-2009, 01:59 PM | #3 |
Man thats awsome i hope it will just bolt and go but with my luck never no what might happen. thanks for the input
05-14-2009, 02:10 PM | #4 |
The output shaft is probably bigger on the Muncie. Clutch spline may be different too. It should bolt right into your existing bellhousing though.
05-14-2009, 02:21 PM | #5 |
I got a straight 6 in it now but i got a 383 stroker ill be bolting it up to if i go this route.
05-14-2009, 06:53 PM | #6 |
You will need a new fine spline clutch, a larger turbo400 style yoke and maybe have to get your driveshaft shortened, and a 4speed shifter for the floor. An M-21 would probably bolt right in.Good luck
05-15-2009, 07:09 AM | #7 | |
Once again, be aware that these "Muscle car" era transmissions were intended to be used in cars with fairly low gears. Once you put it into a heavy truck, the gears become more important. If you have them low enough to drive nicely in town, highway speeds are a bit restricted.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
