Resident of Here
Front sway bar for rear?
Will a front sway bar fit on the rear? What would need to be done to make it fit?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Happy to be here
![]() Join Date: Mar 2000
Re: Front sway bar for rear?
No it won't fit. It can be made to fit with the proper tools....
Resident of Here
Aww. What rear sway bars will fit?
Now this may be useless... but I've seen in the you-pull-its, a rear sway bar (on I believe old fords) that clamp to the axle tube and the ends that mount to the frame by simply drilling a hole. Just a thought.
There's always the stock rear sway sometimes found on duallys. One way to fool a vehicle with poor suspension geometry to handle more like a sports car is to stiffen the suspension. Try 3/4 ton springs. Good shocks would help sway too.
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, Last edited by 79blazer; 05-15-2009 at 03:19 AM. |
Happy to be here
Look for one under a Suburban.
yeller
It might bolt up if this is your truck.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Resident of Here
Thanks guys, I'll have to look at the burbs and duallys nearby.
I posted a while back that I came across a truck that had a sway bar from a mid 70's camaro on the rear of the truck . It was a front sway bar from the Camaro .He did some fabbing of the mounts like muffler clamps holding the factory frame mounts at the axle and he used the sway bar links from the Camaro's sway bar to control arms to mount to the frame . It actually looked factory . He mounted his where the dip in the bar went right over the pinion and it didnt hang below the rear axle . Looked factory .
Frank
Born and proudly residing in a Red State ! |
