Gas Milage
HEY GUYS NICE BOARD JUST A FEW ?S ON GAS MILAGE
I HAVE A 95 WITH A 350 IT GETS 16MILES PRE GALLON OK I DON'T THINK THAT IS BAD.. MY FATHER INLAW HAS A 85Silverado WITH A 305 RUNS GREAT HAS ABOUT 90.000 ON THE CLOCK BUT DOAEN'T USE OIL STILL STRONG BUT SUCKS THE GAS DOWN BAD ,HE HAS NEW PLUGS CAP ROTOR ,,,NOT SURE ABOUT THE WIRES BUT HE GETS ABOUT 8/9 MILES IS THIS NORMAL FOR THIS YEAR TRUCK??? MAN IT IS A VERY NICE CLEAN TRUCK WOULD LOVE TO BUY IT SOME DAY I KNOW IT WILL NEED A REBUILD BY THEN ANY INPUT ON THE MILAGE WOULD BE A GREAT HELP. THANKS .. SORRY NOTICED I HAD CAPS ON... ![]() |
yeller
The 82 I had with a 305 was getting me about 15 MPG, I think 8/9 miles a gallon is not very good for a tuned up 305.
What kind of gears are in back, lower gears (higher numerically) would give you lower MPG but I don't think it would drop it THAT low. Sounds like the carb may be hosed and in need of a rebuild...or new one altogether. -Jeff |
hey bb73 the rear is stock I know that dose not help much..
I'm may sound stupid here as far as the carb I belive it has a tbi.. dose that sound right... |
if its all original then its carbed and has a Q-jet. they didn't start putting tbi in untill 87. has someone swaped it to an 87 and up motor with tbi?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
You get what you pay for
![]() Join Date: Dec 1999
Hey DLE, and welcome.
No, 85 305's had a Q-jet carb. And I agree with Jeff, 8-9 mpg sucks. I also agree it sounds like the carb may need some attention. BTW, TBI didn't come on trucks until 87.
Mike 1985 Chevy C-10 |
![]() HMMMM thanks for the help I thought it was a 85 ok if someone did a swap or say it is an 87 with the tbi /what can he look for to help out the milage i do know it has the tbi but I may be wrong on the year. thanks again DAVID |
BAD BOW-Silverado XST
I get 16-18 in the city with a 305/700R4 tranny with 3.08 gearts. 17-19 on the highway. I would definately start looking into the problem.
Right turn Clyde
I get 4 mpg!! whooo hooo... time to start looking for a good working Q-jet with some slight modifcations. Still need some gears and a small stall convertor. 2.73 gear and 32s right now.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
MPG = 11 - 14
Stock 350 w/ granny 4 speed.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
Garage Queen Material
i get 8-9 mpg with mine
![]() i need a new carb too |
11 city 14 hwy 3.42 28" tires 78 350 148K all stock
#12 | |
HEY THANKS FOR THE HELP I STILL DON'T KNOW WHERE TO TELL
HIM TO CHECK NEXT.. NEW PLUGS CAP ROTOR RUNS GREAT STILL SEEMS TO HAVE PLENTY OF POWER MAYBE A NEW SET OF PLUG WIRES..???I DUNNO THANKS AGAIN HAPPY NEW YEAR |
Changed the Air filter lately !!!!
#15 |
I get horrible gas mileage too, but that might be the hole in the tank too...hehe But I know shes running rich....I was putting on the plates my eyes watered right up and stung and i checked the plugs and they're wet....so I think I'm in the same boat with the carb rebuild. I was thinking about going with a Road demon jr...i don't think i'd need more then 600cfm for a stock 305? and edelbrock sells a adapter to but a squarebore onto a spreadbore...any thoughts?
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
#16 |
My other Love
my 77 silverado with 4.10's and a 400sb I manage to get 15mpg with it on the highway
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#17 |
Check for a collapsed cat. They can sure kill gas milage. What kinda oil is he using? Check the fuel lines for leaks at the pump and the tank switcher. Holes in tanks is a common problem too.
#18 |
THANKS great tips never thought of that..yeah the darn cat
you could be on to something there. as far as leaks it is garage kept and he would notice that. as far as oil i will ask him... ![]() |
#19 |
Ultimate Diesel Dude
I don't drive vehicles with carburetors anymore.....I prefer injection pumps!
![]() Diesel, man! It's the only way to go. I get 18.5 mpg average in a 3/4 ton truck w/4.10 gears! ![]() Don't forget when talking about fuel mileage, that rear end gear ratio, transmission type, and tire size are just as important as any other factor. A truck with 2.73 gears, an overdrive tranny, and large tires will usually get twice the mileage as another truck with a three-speed, 3.73/4.10 gears, and small tires, even if both trucks have the same exact engine.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
