Old 05-16-2009, 02:06 PM   #1
slopesteez
1967 c10 spring and shock set up
i have a 67 c10 and i recently purchased 3' lowered coil springs. i have 2.5 drop spindles and stock shocks. i removed the old coil springs which were poorly cut by the previous owner. i put the new coil springs in and they still dont fit quite right. my stepfather says that the shocks shouldnt be an issue because there should be some pressure on the springs without the shocks and that they should fit. i bought the springs from brotherstrucks.com
also anyone know the stock front spring height
slopesteez is offline   Reply With Quote
Old 05-16-2009, 02:59 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: 1967 c10 spring and shock set up
I'd Like to first say welcome to the board. I don't have an answer your question but would like to send it to the top. There's allot of years and knowledge with our board members. I'm sure you will have your question answered. Good Luck.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 05-16-2009, 03:06 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Three inch springs will fit loosly when the truck is jacked up with no weight on the suspension.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-16-2009, 09:37 PM   #4
slopesteez
tx firefighter----ya there is about a little less than an inch of travel. im worried that if im driving down the road and i hit a bump that i will damage my truck. it just seems like that they are too loose.
Old 05-16-2009, 10:39 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
They will be loose when the truck is in the air with no weight on the suspension. Dont sweat it. Put it together and post some pics.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
