Old 05-19-2009, 04:22 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Vintage Air Cowl block off help
I just put in a Vintage Air Ac system. The kit has you block off the passenger side vent and supplies a plastic plate to do so. On top of that because I installed a custom unit in order to shave the fire wall I had to cut through the cowl system to run my lines and bulkhead. I cut through where the old blower motor goes. So even though I have the vent covered over I have a hole about the same size of the vent cut open that air blows through with no way to plug it off with out some how shutting down that side of my cowl system. Has anyone done this or have any idea of the best way of going about blocking air to the passenger side of my fresh air system? I will see if I have some pictures to show you what I mean. I will try to take some better ones that show the actual hole tonight after work..
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 05-22-2009, 11:40 AM   #2
lts70
1970 Daily Driver
lts70's Avatar
Re: Vintage Air Cowl block off help
Anyone have any ideas?
Old 05-22-2009, 12:59 PM   #3
fastom
That's right, it's Copper!!
fastom's Avatar
That's the best reason for a shaved cowl.
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 05-28-2009, 02:41 PM   #4
lts70
1970 Daily Driver
lts70's Avatar
I do have an extra cowl. How much would you guys say it would cost to have an auto body shop shave the louvers? I know it will be different from place to place, just looking for a rough magnitude. If any one has had it done what has it cost you?
Old 06-01-2009, 01:46 PM   #5
lts70
1970 Daily Driver
lts70's Avatar
Anyone have a guess on what it would cost to shave the cowl?
Old 06-01-2009, 03:23 PM   #6
fastom
fastom's Avatar
I had estimates anywhere from $700 to $1000. Best to try this yourself!
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Old 10-09-2009, 08:49 AM   #7
tinkerdad
I’ve see a smoothed fiberglass cowl for our trucks on this site. Try a search.
tinkerdad is offline   Reply With Quote
