Old 05-19-2009, 04:25 PM   #1
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Brake booster rod
does anyone know where i can get a power brake booster rod for my 71?
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 05-19-2009, 08:37 PM   #2
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Re: Brake booster rod
I converted to power brakes about 2 years ago. A few weeks ago i noticed that the brakes were dragging a little bit. I had made an adjustable brake push rod so I adjusted it out and it was better. Yesterday when I drove it, it was pretty hot out and after about 30 mins the brakes felt like they were applied and I could smell brakes. So my question is, is there any thing you guys can think of to fix this issue. The booster is a stock set but not sure what year its from. any ideas would be great. thanks
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 05-20-2009, 01:39 PM   #3
Sicmaro
Always wrenching!!
Sicmaro's Avatar
anyone?
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 05-20-2009, 04:37 PM   #4
SCOTI
SCOTI's Avatar
I can't provide an answer to your specifc dilemma.
My experience w/my 68 that I swapped later model discs was that I used part of the original brake rod @ the top of the rod (near the dash) & welded that to the bottom half of the donor vehicles rod (where it connects to the Z pivot). I set the length so there was threaded adjustment either way w/no pressure on either end & never had any problems (half of a Power Tour one year & multiple trips to the Hoston area from DFW Tx).
This will give you a bump & maybe someone else will have an answer shortly.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-20-2009, 07:43 PM   #5
JimKshortstep4x4
If the brakes are dragging I would suspect something other then the brake booster rod. Check the booster to master cylinder rod clearance. if only one end is dragging check the brake hoses to make sure they are not plugged.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-20-2009, 07:53 PM   #6
68gmsee
Active Member
68gmsee's Avatar
If the brakes are not releasing and everything adjusted correctly, suspect the rubber hoses going to the brakes from the frame. two in the front and one in the rear above the drive axle. They swell from the inside and won't let the fluid return properly. In some cases it just stops returning and locks up your brakes.
Can't tell from looking at them. To test, raise the wheels, apply the brakes with engine running and check to see if the brakes released.
68gmsee is offline   Reply With Quote
