Old 05-23-2009, 05:19 PM   #1
71 super
71 super's Avatar
Unhappy Carb help
First some background: My 71 sits alot- I crank it (not as often as I should) but enough to keep battery up. Anyway a month or so I take it for a short drive just to move the parts around a bit and it began to sputter and hestitate. It died and after a few tense moments I got it started again and back into the garage. First thoght bad gas, so I drain nearly 5 gallons out, replace fuel filter and check the fuel lines for collapsing pieces. I replaced the line (rubber) that come from frame to pump. No help. Fast forward to last week, buy a kit for the carb install it without a hitch crank it up and if anything it was worse or at least not better. It burns your eyes at the exhaust idle fluctuates like a vac leak yet nothing is showing (WD40 around base and hands over throat). Fast forward again, getting ready for a local show drive to community gas station nothing is better and had to start with starting fluid, then it just shuts off like key was switched off. Crack the line at carb and zero gas at filter. I think maybe fuel pump, replace that as it was cheap and still doing the same, but at least it ran to get it home. Any thoughts or suggestions???? All are appreciated.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-23-2009, 05:37 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Carb help
I hope you drained the tank and flushed out the line. The replaced the filter. If still no gas to the carb then check the pick-up in the tank.there's a "sock" filter on there. Check that the intake isn't clogged with rust etc.(I would bet that's the poblem) So then if still no gas I would double check the line and tightness of connections as it could be sucking air,but you would probably see gas leaking with the engine off.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-23-2009, 05:47 PM   #3
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: Carb help
Either that or you may have some water in the tank.
Just a thought.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 05-23-2009, 07:35 PM   #4
Muleman100
Muleman100's Avatar
Re: Carb help
Check fuel pump, take line off at carb, turn over engine and see if fuel is pumped to the carb. If filter is OK it could be the fuel pump.
JH
Muleman100 is offline   Reply With Quote
Old 05-23-2009, 09:12 PM   #5
71 super
71 super's Avatar
Re: Carb help
The fuel pump was replaced today in parking lot of gas station. The fuel filter was also changed today. The motor is stock but with 18-20 inches of vac. but when I put vac guage on it today only pulling 12 -14 inches of vac. I had to turn idle screw in quite a bit just to keep idling. This pushes me toward carb issues. The carb was built by jet about 6 years ago, but I refreshened it up last week. The only thing I could find was the plunger diaphram waded up around the spring in the accellerator pump. The kit I put in was a delco kit and float did not show sinks of sinking etc.
Old 05-25-2009, 08:24 AM   #6
Muleman100
Muleman100's Avatar
Re: Carb help
Must be the carb and probably the pump.
JH
