Old 05-24-2009, 10:01 AM   #1
mainermikeyd
mainermikeyd's Avatar
Question Edelbrock carb question
1405 edelbrock carb on GM crate motor, with performer inatake where are you guys connecting your vaccum advance on the carb?? passenger side port or drivers side vaccum port?? Drivers side is full vaccum correct, as in it sucks all the time, yes no???
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 05-24-2009, 10:39 AM   #2
boatpuller
boatpuller's Avatar
Re: Edelbrock carb question
i believe....now,i'm going off memory which is a little scary..mine's off the left passenger side.the right is the pcv valve...i think.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-24-2009, 01:24 PM   #3
78 Chevyrado
I can't remember which does what off hand and I have a 1406, but My vaccum advance is connected on the drivers side small front port. The passenger side small front port is capped with a rubber cap.
The terms are Ported Vaccum and unported vaccum. One creates vaccum at idle, and the other creates vaccum with the throttle open.
78 Chevyrado is offline   Reply With Quote
Old 05-24-2009, 07:26 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I run mine on ported (passenger side).
You can run either side. All you need to to is set initial timing for the side you want to use. I like using the full vacuum port at the track. Use ported for fuel milage and full for performance.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-25-2009, 10:43 AM   #5
boatpuller
boatpuller's Avatar
i took a look......left or passenger side goes to the vacum advance.the right port is capped off.and the large center goes to pvc.as gchemist said you can run off either. but cap off the other.
Old 05-25-2009, 10:48 AM   #6
vtwinsport
vtwinsport's Avatar
i run it off the ported side (psgnr). makes daily driving much better.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 05-25-2009, 10:53 AM   #7
Pyrotechnic
Pyrotechnic's Avatar
Depends what your distributor is set up for. Any HEI and most aftermarket distributors these days are set up for ported vacuum.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-28-2009, 07:37 AM   #8
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Dang boat, i could eat a good hot dnner off that motor!
87Lowrider is offline   Reply With Quote
Old 05-28-2009, 11:01 PM   #9
boatpuller
boatpuller's Avatar
kenny,you'd have to cook it bud.i'm only good for toast and that's even iffy.
Old 05-25-2009, 11:06 AM   #10
mainermikeyd
Thanks for the help guys, it helps when you have a place like this to have open discussions about which is what, or what may work better driving on the street vs. at the track or off-roading!!! BTW off my vacuum advance there is a T which also runs to the tranny is this correct??
GM Fanatic
Old 05-25-2009, 03:25 PM   #11
vtwinsport
vtwinsport's Avatar
no problem.
sounds like it could work but usually the vacuum for the tranny is connected to a outlet behind the carb, on the intake. Usually, there is an outlet with a couple stubs on it; one for the tranny, one for the vacuum on the brake diaphram for power brakes. I've seen numerous setups but you certainly want good, direct intake vacuum to those two. If it's working fine, leave it I say.
FWIW
Old 05-25-2009, 09:50 PM   #12
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
That will do it.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-28-2009, 11:49 PM   #13
asphaltburner
asphaltburner's Avatar
Yo!
Proper vacuum for distributor advance should be to a port that has no vacuum at idle, but applies vacuum with opening of the throttle.
You can tell if the port has vacuum by placing the tip of your finger over the port while the engine idles. Then open the throttle to check vacuum at higher rpms.
Applying vacuum to the distibutor at idle will advance your initial timing changing your advance curve,...and since there's three components to that curve (and it should be set sequentially for proper performance), it would be detrimental to perfomance timing.
Timing should be set initially with vacuum plugged. Run full throttle runs, advancing the timing in two degree increments until some predetonation occurs. Then attach vacuum. If an adjustable vacuum is used, mid-throttle runs cans be used to adjust for some slight predetonation to adjust the total engine advance to the best possible performance, with the least predetonation.
Timing is: initial timing (timing marks), centrifugal advance (weights and springs in the distributor), and vacuum advance (zero at idle, increasing with throttle), and should be set that way for a total of 45 to 55 degrees.
Hope that helps,...questions? Email me at wetminkey@hotmail.com, or PM asphaltburner,...I'm happy to help with this misunderstood aspect of engine tuning!
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 04-21-2011, 11:32 PM   #14
CEE1NG_RED
Originally Posted by asphaltburner View Post
Yo!
Todd.
Huh??
I will need to do this to my 1405 since the PO capped/plugged both sides causing my dipstick to come off. Now, from my understanding...the best place for daily driving is on the passenger side (where the PCV hose to be connected to the 1405, correct??? Now, will that require adjustment on the timing? If so, how can this be done? I haven't started the car since I bought it and with limited timing leaves me no time to fix this until this weekend, when I have some time.
Thanks in advance...
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 04-22-2011, 01:12 PM   #15
willstruck
Originally Posted by CEE1NG_RED View Post
Huh??
Block the line going to the distributor to set the timing. Doesn't matter what port you normally have it hooked to, pull the hose off the carb and block the hose. It really only takes maybe 5 minutes to do the timing. You just need the gun, and a 9/16 wrench. 11 degrees BTC or so seems to be fine for a SBC, factory specs is 4.
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
