Heater valve on inner fender.. can I eliminate it?
I'm missing most of my AC stuff. In time I'll be going the AC delete route and cleaning up my firewall. So, I'm not planning on putting AC back in my truck (if I decide to later there's always Vintage Air). I believe after reading this:
That I can just run the hose back bypassing this valve with no effect. I just want my heat to still work. Thanks for the preliminary answer Longhorn Man.. just making sure I understand things correctly.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) |
Moderator
![]() Join Date: May 2007
Re: Heater valve on inner fender.. can I eliminate it?
That valve shuts off hot antifreeze from going thru the heater core when the A/C is on. Since the heater core and A/C evaporator core sit right next to each other, this keeps the heater core from heating up and cancelling out the A/C.
To answer your question, yes you can eliminate it if you are not using A/C. Just make sure that you cap off the vacuum source to it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-24-2009 at 04:50 PM. |
Thanks man.
Redefining LowBudget
thanx for the info but I have the same desease but plan on fixing my A/C what are you removing Mine has been raped of all the the lines and condesers
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
