05-24-2009, 06:45 PM | #1 |
no more 2wd to 4wd
ive decided to be content with my 2wd and install a locker for traction aid what do ya'll recommednd i know this is 4x4 section but i need help
i have a 2wd 2 door silverado with 4.3 and auto trans
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
05-24-2009, 07:18 PM | #2 |
Grease Monkey
Re: no more 2wd to 4wd
I'd go with a posi. It will be easier on the tires when you're are the street
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
05-25-2009, 06:07 PM | #3 |
Do you know if its a gm 12 axle it looks like one but not sure
05-25-2009, 06:11 PM | #4 |
Grease Monkey
need a pic of the diff cover. but that sounds right
05-27-2009, 08:03 PM | #5 |
I would look at doing an Eaton E-Locker or Detroit Electrac. These units are positractions. The Eaton is a clutch type and the Detroit a gear drive Tru-Trac type. Then you push a button and they are truly and completey locked. The best of both IMO. Another option would be an Ox Locker, but I like the others better for a streeter, especially a 2x4.
Edit: the Auburn Ected is another choice for a limited slip & then locker with the push of a button
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 05-27-2009 at 08:07 PM. |
