05-28-2009, 07:45 AM | #1 |
3 Heater system questions
1.0 The heater core has one big tube and one small tube sticking out of the firewall to hook to the hoses. Which way does the heater core go in, is the big tube supposed to be on top or bottom? Does it matter?
2.0 Defrost duct hoses: In LMC they have "OE type" hoses for around $30 and then they have hoses for around $15... I guess they're not "OE style". My question is; what is the difference in these ducting hoses? Are the $15 ones better? rubber? don't fit well? come in one piece and I'll have to cut them to length? what is different about them? Why are they $15 cheaper? Anyone know anything about the cheaper ones? 3.0 [B]Heater resistor[B]: What does this thing do? Does it go bad often? How can I tell if it is bad? I cleaned mine up and blew it off and it looks great. I'm putting the heater box back in and was wondering if I should bother with replacing it or not. |
05-28-2009, 08:28 AM | #2 |
Re: 3 Heater system questions
02. Don't get the cheap duct hoses, you will regret it. They are aweful, been there, done that.
Garry 1968 LWB C20 1969 Blazer 1972 Suburban 1989 Suburban (Beast) |
05-28-2009, 09:11 AM | #3 |
Thanks garryk
Now guys, what about number 1 and 2? |
05-28-2009, 09:42 AM | #4 |
Firefighter
No.1 It does not matter, I put the small on top and large one on bottom.
No.2 Get the OE style hoses, the other kind are like a plastic that will not fit very well. No.3 Resistor controls blower speeds, low med and high, if it goes bad you may only have 1 or 2 speeds, usually low and high or sometimes low and med.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
05-28-2009, 10:18 AM | #5 |
425hp409
It does matter which way you put the heater core in the case. The coolant needs to flow from the bottom to the top to push the air out and enable complete filling of the core for maximum heat and no air locking in the core. The small hose is the inlet bringing coolant from the top of the engine and the large hose is the return. Therefore, the small hose is always on the bottom and the large hose is always on the top. All cars and trucks are like this. The only time it does not matter is if the hoses are side by side.
If the resistor looks OK, that is no burnt coils or connections, it is probably OK. Charles Last edited by 425HP409; 05-28-2009 at 10:19 AM. |
05-28-2009, 01:11 PM | #6 | |
Now I'm going to take the core back out of the box and flip it over to where the small tube is on bottom to make sure that everything works correctly. Its aggravating to get those little brackets to align with the holes in the side of the box and get the screws in. Thanks for the help. |
05-29-2009, 12:06 AM | #7 | |
its all about the +6 inches
05-29-2009, 05:51 AM | #8 |
ENGINE BUILDER
Mine works good too even with the hole in the floor next to my rusty rocker panel!!!!
JIM ZAG |
05-28-2009, 01:48 PM | #9 |
Black and Blue I agree with you and I think that it probably WILL work just fine, also, it looks better because your hoses are not crossed.
However, since I have it all out and on the bench I'm going to do it properly. I've looked at some pictures of others and they have the small hose running to the bottom as it should be too, so I'm pretty sure that the small hose to the bottom is the correct way to do it. |
05-29-2009, 04:57 PM | #10 |
I am a Referee of life.
I turned mine so the hoses didn't have to cross.Small things like that just seem to clean up the engine compartment(not that mine is that clean and neat yet).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
