05-28-2009, 05:32 PM | #1 |
83 c-10, spongy brake pedal
Hey everyone, I have a problem. First let me give you the details. It's a 83 c-10, long-bed. It has a 305 and 700r4. I purchased the truck with a spongy brake pedal. I have since replaced both front calipers and brake pads. I can't find any leaks with the system. I bleed the heck out of the thing and it fill get firm for maybe 3 pumps and thing "leak down". Also the truck has front disc brakes, but no power brakes.
Maybe someone jas had this problem before?? Any suggestions would be great.Thanks in advance. |
05-28-2009, 11:03 PM | #2 |
Robert Olson Transport
Re: 83 c-10, spongy brake pedal
im thinking the master cylinder
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
05-29-2009, 02:11 AM | #3 |
78 Big10 454
I'm with old Rusty c10 on this one.
05-29-2009, 06:56 AM | #4 |
Could be leaking internally. Remove it and check the rear seal.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
05-29-2009, 08:10 AM | #5 |
Happy to be here
Yep, sounds like it. While you are rebuilding the system consider replacing the rubber lines at the caliper. They are prone to create a soft pedal as well. Not a leak down as is the case here.
05-29-2009, 10:32 AM | #6 |
thanks guys, it def. feels more of like a "leak down" than a spongy feeling. My next thing is too replace the front caliper rubber lines and the master cylinder, probly this weekend.
05-29-2009, 10:57 AM | #7 |
Happy to be here
Report back with your results...
05-29-2009, 11:01 AM | #8 |
Whats your fluid look like, is it still clear or is it black. I had a similar problem with mine and replaced the booster and master cylinder. That made it better but still felt strange. I pumped out the old black fluid and replacing it with fresh fluid and now it feels like a new truck.
05-29-2009, 11:11 PM | #9 |
Joe R , replacing your brake fluid will make the truck perform better. Over time the fluid will absorb moisture and causing it to reduce it's boiling point. Moisture in a brake system can cause components seals to fail, pitting in calipers and wheel cylinders and it breaks down all rubber components (hoses). I usually change my fluid every year. Most maunfacturers recommend between 25 and 30k miles.
