05-29-2009, 09:30 AM | #1 |
'69 Chevy SWB
sway bar bushings?
I bought a sway bar from a member and I was wondering, where is a good place to get poly bushings for it? Here is the link to the bar.
http://67-72chevytrucks.com/vboard/s...d.php?t=344436 would universal bushings work ok? I've looked at summit and jegs and they don't have any listed for a 1" bar (vehicle specific) but they do have universals. What have you guys done? |
05-29-2009, 09:37 AM | #2 |
motor exploder
Re: sway bar bushings?
can you post the link the summit/jegs pages for the bushings? have you tried Energy Suspension? www.p-s-t.com may have them.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-29-2009, 09:42 AM | #3 |
'69 Chevy SWB
Jegs
http://www.jegs.com/p/Prothane/Proth...81833/10002/-1 Summit (for chevy) http://store.summitracing.com/egnsea...115+4294907049 Summit (universal) http://store.summitracing.com/egnsea...115+4294907049 |
05-29-2009, 10:00 AM | #4 |
I think the factory sway bar is 1-1/16" .
ECE sells a kit with polygraphite bushing / straps & hardware . Part# 02-35175G http://www.earlyclassic.com/catalog.aspx
Working on my first 1,000 post. I'm sure I'll get there before this project is over . |
05-29-2009, 10:03 AM | #5 |
'69 Chevy SWB
I'm not sure on the size, but the member I bought it from said 1". I'll measure it with a caliper when it gets here to know for sure though.
05-30-2009, 04:00 AM | #6 |
'69 Chevy SWB
Back TTT, any one know if universals will fit?
05-30-2009, 05:15 AM | #7 |
67-72 parts collector,…
Just measure your bar and buy the correct size Energy Suspension Bushings. They can be found at your local Autozone. They also come with the clamps.
05-30-2009, 01:03 PM | #8 |
Watch out for your cornhole !
Most parts stores will stock the nice Moog brand urethane ones too.
