05-30-2009, 09:36 AM | #1 |
Front End Rebuild Replace Repair
Hi
I'm stripping down the front end of my truck and wondering what you guys think should I replace everything since I have it apart? I will replace all the joints should I rebuild the wheels cylinders and calipers turn the rotors? or just replace them? What about the hardware can it be reused or replace? I have the rest of the truck down to the frame just need some input Thanks
Rolled the dice and lost!! Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
05-30-2009, 09:56 AM | #2 |
I am a Referee of life.
Re: Front End Rebuild Replace Repair
Since it's to the frame ,I would replace anything vaguely marginal.When you finish a frame off you will want to cruise it instead of having to fix stuff you didn't repair/replace.I wouldn't replace calipers unless I thought they were original or they leaked.I would turn the rotors and repack the wheel bearings.I would replace the hoses for the brakes.It's easier with the body out of the way and unless they've been replaced they are 40 years old.The bolts and such should be fine unless they are badly rusted or threads are bad.Replace any that don't seem to unbolt well or that have skinny spots from rust/wear.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 05-30-2009 at 09:58 AM. |
05-30-2009, 10:01 AM | #3 |
Grandpa in the rustmobile...
i replaced everything..well...alot lol
wheel bearings rotors (like 20 bucks) used old calipers new pads newballjoints tierodends etc
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-30-2009, 11:58 AM | #4 |
wheel cylinders and calipers are sooo cheap that if need just go to the local autoparts store and get them off the shelf
05-30-2009, 12:58 PM | #5 |
Watch out for your cornhole !
I agree. A pair of calipers is going to run about 30 bucks from the parts store. Replace them. You can never tell how much corrosion is on the inside of them.
05-31-2009, 08:52 PM | #6 |
What about disk rotors turn them or get new?
05-31-2009, 08:59 PM | #7 |
No sence in throwing away a set of good rotors as long as they are thick enough to be serviceable. There is nothing really that goes wrong with them. I don't even turn them unless they need it either. No sense in removing material from them needlessly. Your brake pads will wipe any moderate rust right off of them within the first few feet of use.
