Grandpa in the rustmobile...
getting rally wheels that need painting..
found 4 15/8 rally wheels 5 lug that need sandblasting and painting, whats the color called, the silver looking color?
should i spraybomb them, or spend the extra $ and do it right, how much would paint/primer be for them, where can i get it at, and how much do i need? can i sandblast the wheels with tires already on them or no? and does $100 sound like a deal, or no deal for the wheels, this is MAYBE with caps included... Thanks!!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Under Construction
Re: getting rally wheels that need painting..
The color is argent silver... asa far as price, depends of the condition of the tires. they go for about 20 each with rings around here
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
guy wants 25 apiece with no tires i need to get something that ima keep on the frontend before i take it to get an alignment lol i can paint em later, (preferb. with the tires on too)
It's hard to paint them right with the tires on the wheels.
100 might not be out of line if all the caps and rings are close to perfect. I don't know what they go for around here but the 20/25 price range is probably close. Lately though anything that can be called "Rally" seems to comand a stiff price. Last edited by mr48chev; 05-30-2009 at 11:14 AM. |
im not sure if i got 15x7 or 15x8 front wheels....if i have 15x7 wheels..will my tires that i already havfe fit the wider 15/8 wheels? thanks
Need to know the tire size, then there are charts you can check on the different tire sites.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
$100.00 is a very good deal around here...I would strip the paint, primer them then spray paint...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Looks good at 20-ft .....
$ 125 for five. The caps & trim rings were scrounged & cheap. The narrow (van) trim rings are very slightly mis-matched on the right & left side of the truck, but nobody but me seems to ever see it.
No sandblaster available at the time that I wanted to roll with them, & no argent silver at O'Reilly's, so it was wire brush on an electric drill, wipe clean with thinner, & WalMart rattle can silver. Two days hardening time & the new tires went on. Definitely they're "wrong" compared to being truly correct, but these wheels never came on these trucks anyhow !!! Grandad always said: "Boy, poor folks like us has poor ways." Several years later, they still look pretty good, and the shiny silver has faded a bit to look a lot more argent-like. |
I am a Referee of life.
I paid $150.00 with caps and rings.I didn't want to use a silver so painted mine Metallic Charcoal.The rings are in great shape the caps are ok but I don't like the 4X4 caps.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Blaze-Air
Just wire brush with a drill attachment. Get the crud off. Sand them with 150-220 to get all the imperfections blended out, prime gray, sand with 800. Wash the rims with light soapy solution. Rinse very well. Make sure ALL moisture is gone. Paint. Go light first coat. I like to lay a heavy second coat. 3rd coat if necessary. Done. Clear if you like.
FYI. I just painted a set with plasti-kote argent silver p/n 621. I had a can of aluminum paint also. I can't tell the difference. I feel the argent although correct, is too bright. I wound up using plasti-kote steel, p/n 618. It's a shade or two darker and trim rings and center caps contrast well. |
I sanded mine, primed them and painted them with metalic silver, I know it's not the factory color but I like it.
I like those caps - where did you get them?
Never Ending Projects
The reason you didn't see them is that your rally's are car rally wheels, done by an aftermarket company. GM never made this style of rally for the trucks. Your center cap is the same they used on GM cars like Camaro's, Impala's, etc. They look great, especially on trucks but they are not truck rally's like the other ones being posted.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#15 |
its all about the +6 inches
I highly recomend NOT going with chemical stripper. Sand blast them, sand them by hand, wire wheel them... but no chemicals.
#16 |
Here are mine. I just used aluminum silver enamle with a couple coats of clear. Wouldent suggest using aluminum silver unless your clear coating it, without clear coat they just look cheap
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
#17 |
tires on my 68 are 235/?/15 the wheels i need to put them on are either 15/8 15/7 my choice...some wheels are greyish, some are white lol
#18 |
oh and can i get a color in rattlecan close to the argent silver, and do you guys recommend clearcoating the wheels? can i get spraybomb clearrcoat
#19 | |
Blaze-Air
#20 |
SLOW BUT SURE,BUT CLOSER
Clean em' and paint em'!!! All you see is the middle with caps and rings. I tend to laugh when I see or read about blasted and p/coated ralleys. Over done and over spent for a $25 wheel IMO.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#21 |
Mine are painted same color as truck
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
#22 |
Autozone has a silver wheel paint that's very close.
#23 |
so should i wirewheel the paint off or sandblast? id like to sandblast a bumper too
#24 |
If their not scratched and scarred up real bad take a scotch brite pad and mix up some soapy water (we use to use spic n' span powder) and scrub them real good. That's all I did to mine and they still look good after 17 years(when they're clean lol).
#25 |
there pretty bad from what i remember lol, 1 or 2 are white lol
heres the plan: wake up go to bank return swirly wheel back to dude (i was gonna buy these, "dylan" on here has some) schedule an alignment get rally wheels (not sure if i get fronts or front/rear) get my old rallys/tires and put the tires on my 5 lug wheels... have tireplace put 5lugrallys/old 6 lug rallystires on my blue truck drive home happy with matching wheels then see about a 5 lug reraend lol oh and get paint or paintandsand
