1985 GMC Jimmy gear ratio?
Does anyone know what rear axle gear ratios were offered in 1985 GMC Jimmy K5 - 12 bolt?
I have tried to do some looking on the old brochure sites but the fine print is too fine to read. ![]() Thanks in advance.
1972 LWB 1969 4x4 Suburban 1989 4x4 Jimmy |
Re: 1985 GMC Jimmy gear ratio?
Not that it matters, but will be 10 bolts front and rear. And gears could be anything from 2.73s up to 4.10s. Check in the glove box for the RPO codes, or could be under the hood on the inner fender. Starts with a "G".
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by b454rat; 05-31-2009 at 09:09 AM. |
Well I thought 10 bolt too but the guy who has the truck says that the rear is 12 bolt.
Take the covers off of the diffs and count the number of teeth on the ring gear and divide it by the teeth on the pinion.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Parts and more parts
My truck has a 12 bolt rear end and it is an 84 Sierra classic. The gearing could be 3.08, 3.42, 3.73, or 4.10. In those days you could STILL order what you wanted in a truck.
Right on about counting teeth or sometimes there is a number stamped on the ring gear that you can devide to get the ratio. I was asking because I do not have the Jimmy in my possession. I am going to pick up the front and rear axles tomorrow without know what ratio they are. I am just hoping that they are not 3.08.
