05-31-2009, 11:01 PM | #1 |
pro gears in truck rear
just wanted to let everyone know it can be done. just installed moser 4:88 pro gears for a 12 bolt car rear in my truck, 1 pinion bearing is the only difference. i can get the bearing numbers if needed or call moser. i checked the application on the bearing and its for a newer chevy truck rear or an international. i work at napa so i got my bearings at work or moser can supply them. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
05-31-2009, 11:15 PM | #2 |
Dr. Frankenstein
Re: pro gears in truck rear
is that said 12bolt in the picture? looks like you have some other work into To get them front hoops off the ground....care to share what?
I Wanna Go Fast!! |
05-31-2009, 11:24 PM | #3 |
60-66 Nut
I'd like to know what the bearing number is if you don't mind.
Oh and some more info on your truck too.....
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-31-2009 at 11:25 PM. |
05-31-2009, 11:34 PM | #4 |
iron headed 406, all motor. about 12:1, lunati solid and a 750 holley. auto gear m-22 four speed. the rear has moser axles and spool, lpw cover and back brace, tubes are welded. trailing arms are plated top and bottom and boxed in (bent one from launching). stock truck springs with lakewood shocks for a chevelle (had to flip shock mounts from side to side) anything else just ask. Dev.
06-01-2009, 07:41 AM | #5 |
That would definitely be some good info to have.
06-01-2009, 12:03 PM | #6 |
Dr. Frankenstein
oooooooo m-22! awwwwwwwwww
I Wanna Go Fast!! |
06-01-2009, 08:08 PM | #7 |
BAD BOW-Silverado XST
The picture sucks.....where's the video??
06-01-2009, 11:34 PM | #8 |
looking good
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-01-2009, 11:58 PM | #9 |
Man are our ET's and MPH NA very close to each other.. What's that truck of yours weigh?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
06-02-2009, 03:09 AM | #10 |
very sweet truck. nice to see another gear jammer. i swear you copied mine. lol. hows autogear's super case? i've been think about gettin one. also, what rpm you leaving at? chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
06-02-2009, 07:38 AM | #11 |
The supercase is impressive in person. VERY beefy.
06-02-2009, 08:00 PM | #12 |
super 73, i gotta weight it again at the track, i weighed it once at a local truck scale and it said 3300#, don't know if its really that light.
71. don't worry, no copies here i put this one together about 6 years ago. also glad to see someone else who isn't afraid to go old school with a 4 speed. launches nice around 4-4500 supercase is very nice, mine is all autogear on the outside and all internals are from a place called four gear trans. he doesn't think the maserio gears were strong enough so he made his own that are stronger and relieved for better oiling and some other tricks. he says it will take 750 hp. super nice guy to deal with too.
02-05-2013, 10:40 AM | #13 | |
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) |
02-14-2013, 11:19 PM | #14 |
don't know if his are any stronger, but i can say i've been 11.80's, pulled the front wheels, and flat shift it all the time, so far so good, and he is a great guy to deal with, super nice, and highly recomended.
06-02-2009, 11:55 PM | #15 |
its all good. that nice to know, ill have to keep him in mind if i blow mine up. im runnin a m-20 with stock everything with an iron midplate. i'm leaving at 5200 on the 2-step. what's your 60ft times? you runnin regular clutch or one with an adjustable pressure plate and iron disc?
06-03-2009, 06:06 AM | #16 |
moser told me that a billet 1350 yoke from a car wouldn't work on our 12bolts, but i ordered one anyway from them just to make sure, and they do...drivetrain specialist here in okc told me that they would work.... What rearend cover do you have on yours?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
06-03-2009, 03:11 PM | #17 |
5200 wow that must be fun. i was thinking of getting a 2 step, what did you switch yours from the line loc or the pedal?? 60ft times are in the 1.6-1.7 range. does the m-20 seem to make the rpm drop off on the top end? i had one in my truck when i first put it together and then destroyed it and switched to an m-21, seemed to help on the 3-4 shift, and with 4;88's it still leaves hard. eventually exploded the 21, hopefully this one takes the abuse.
i did have a ta performance cover on before i put the rear brace on but then i had to get the cover from lpw to use the back brace.
06-03-2009, 03:33 PM | #18 |
its is, bout pulls the front tires. wanna try higher but i dunno if the trans can take it. im nornally in 1.69-1.71 60ft. got the 2-step wired off the line lock switch, since im still shifting with the clutch if didnt make much sense to it off the clutch. it worth the money tho, so nice not havin to watch the tach and the tree, helped out with my lights a lot. 3-4 deffently sucks, i shift around 6300 and it drop to around 4800, but i think havin the lower first gear makes up for. i had a 21 in it with a 3.73 on the street and then swtiched to the 20 and noticed a huge difference. now that its track only, i put a 4.88 in it, and have never ran it with the 21. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's Last edited by 71chevytruckguy; 06-03-2009 at 03:34 PM. |
06-03-2009, 07:53 PM | #19 |
My super t-10 is a 2.64/1.75/1.34/1.00. 1-2 is a pretty big drop, but it seems to be a pretty good compromise.
08-29-2009, 10:54 PM | #20 |
I know this is kind of an old thread, but I'm building a 68 GMC shorty stepside for the 1/4 mile. I'm currently running a 350 TBI, 3 speed saginaw and 12 bolt rear with minispool. It's a budget build, and I haven't touched in it a year or so, so forgive me if I forget a few things. I think I have 4:10 gears in it, and I have a Muncie built for it, I believe the M-21 close ratio. Couple things, where is the best place to get a 1350 yoke for a 12 bolt? Do you know what bellhousing I should look for to swap in the Muncie? I know they came stock, but I do not know what years. Also, I am planning on a fuel cell in the box along with the battery. How big a problem is it to get traction in these trucks?
08-30-2009, 10:23 PM | #21 | |
Mean Green
I've been trying all summer long to drop a high 11. What size slick do you run? |
09-02-2009, 07:36 PM | #22 |
im running a 30x12.50-15 et street.
you can get the 1350 yoke from moser and it will fit right on no problem. i never have a traction issue, im sure if you try to run street tires you will but with slicks i pull the left front wheel every pass and have stock truck coils in the rear and lakewood 50/50 shocks. if your gonna race it regularly with the stick go for the blowproof bell, im sure it would be harder to drive with half your foot missing from a clutch explosion. dev
01-12-2010, 12:45 AM | #23 |
What's the number of the bearing needing? Also, can you use the truck yoke with car gears. Found a set of used 5.38 pro gears on ebay. Thanks. Chris.
01-26-2010, 12:37 AM | #24 |
TTT for the magic bearing.
02-11-2010, 03:00 AM | #25 |
ttt, I've searched all over the internet, crossed bearing numbers from timken for a 90 and up 1/2 ton chevy truck and still no luck. Hate to think I wasted $100 on a set of gears I can't use. Chris.
