Fuse Box
I'm trying to remove my fuse box so I can run a wire for new lighting. What's the trick to doing this?
ChevyChic 86 Chevy K-10 If I can't be a good example, then I'll just have to be a horrible warning. "You're braver than you believe, and stronger than you seem, and smarter than you think" - Christopher Robin |
You get what you pay for
![]() Join Date: Dec 1999
Heather,
I wouldn't remove the fuse box. Do you not have places left on the front for wires? There should be some ign, and bat spaces. Are you wanting these new lights to come on with the dash lights? If so, find the gray wire that feeds the instrument cluster and install a power strip to connect the new wires to. How many wires are you needing to run anyway?
Mike 1985 Chevy C-10 |
I do have spaces left, I didn't even think of using those. Sorry, I can have a one track mind and sometimes miss the obvious alternative. I was hoping to run 3 lights into one lead and then to the fuse box. They're operated by a toggle switch in my dash so they'll be independant of all my other lights.
What size connection do I need to plug into the front of the box?
I would splice the three wires to one, solder the joints, and tape them. Or for a quick connection, use a wire nut. Fasten it to the toggle switch, then go from the toggle to fuse panel. I use male spade terminals to plug into the fuse panel. The ones I use are around 1/4" wide. Works like a charm.
Oh, don't forget to use an inline fuse. The front of the fuse panel isn't fused. A 10 amp fuse should work.
