06-04-2009, 02:17 AM | #1 |
Engine Angle in stock 4wd
I'm swapping in an LS2 and 6L90 into my 4wd. The best angle I can get without transmission tunnel work or dropping the motor mounts down is about 6 degrees rear tilt. I don't know yet if that will be driveline angle problem on the front but I was curious what the stock engine angle is. Anyone out there measured it?
Thanks, Whit |
06-04-2009, 03:00 AM | #2 |
Freeeeee Mason...
Re: Engine Angle in stock 4wd
4L80e FTW, You'll have major issues putting the 6L90 in there. =/
Daily Driver -2007 Chevy -Dark Blue Metallic -Regular Cab -4.8 V8 -4x4 Ongoing, Never Ending, PITA, Love of my Life -69 Chevy C/10, Camper Special -350/TH400 -Loudest System on the Board Last edited by Pl4yboy; 06-04-2009 at 03:01 AM. |
06-04-2009, 11:15 AM | #3 |
The only major issue was that I needed to change out the reluctor wheel and cam gear to work with the E38 PCM that the 6L90 needs. Now I'm just down to the basic cut and weld stuff.
