Old 06-04-2009, 01:26 PM   #1
tranz am
tranz am's Avatar
help with pinion shaft thickness!!
Im about to order up a set of gears for my 69 but it looks like 2 different pinion shaft sizes were used in the 12 bolt over the years. 1.438 in. & 1.436 in.
The rear end in my truck is a stock 1969 12 bolt. What size do I have? Thanks.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 06-04-2009, 01:59 PM   #2
tranz am
tranz am's Avatar
Re: help with pinion shaft thickness!!
Ok figured it out, I guess it depends on the carrier you have. I have a 3:40 or lower carrier so its the 1.438" pinion shaft or 3 series carrier. The stock carrier for my truck for the 3:90 was a 4 series carrier, thats the 1.436 dia pinion shaft. Thanks for looking guys, have a great one!
My build thread
1969 GMC SWB
Old 06-04-2009, 04:56 PM   #3
71tahoe
71tahoe's Avatar
I only know car vs truck. 1.625 vs 1.438
71tahoe is offline   Reply With Quote
Old 06-05-2009, 12:34 PM   #4
tranz am
tranz am's Avatar
I find strange that the pinion shaft on a car 12 bolt would be thicker. It should be the opposite imo.
My build thread
1969 GMC SWB
Old 06-05-2009, 12:45 PM   #5
71tahoe
71tahoe's Avatar
It may not be based on the load that could be hauled but the relative gear ratios. Lower gears in trucks (higher numerically) likely apply a smaller torsional load to the pinion than a higher gear in a car.
Old 06-15-2009, 12:42 AM   #6
tranz am
tranz am's Avatar
good point.
My build thread
1969 GMC SWB
Old 06-15-2009, 07:17 AM   #7
Shaky
Six in a row makes it go...
Shaky's Avatar
Yeah, but .002 inch? That's probably within the tolerance on the diameter.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
