![]() Join Date: May 2009
Bunch of ??? in one post...
I want to make sure brake fliud is ok to use in my clutch slave cylinder?
Last edited by N2TRUX; 06-04-2009 at 07:39 PM. Reason: No, a What's it Worth is no OK. |
Low & Fast!
Re: Bunch of ??? in one post...
Hey man I under stand that you trying to find out what your stuff is worth, but you can not sell on here if your not a subscriber. And I know you have not said it's for sell, but I know it will make it's way to that. You can also look on ebay to see what stuff is going for..
And I not sure about the brake fluid I would check a Auto parts place for clutch fluid. Thanks, Trav
Thanks TVBlazer, Ive searched Ebay, CL, even here and prices vary alot... Just tryin to get a feel for what stuff is worth... Right now its worthless since I dont have it for sale... The rears were gonna be used, I was gonna regear them with 5:13's and put 20 inch wheels wrapped in 54"s of bogger, but money is an issue and the plans changed... I spent time wire brushing them and spraying them with paint...
I read the rules... Just tryin to get an idea.... mainly on what teh rears are worth... Also I had an older Non Chevy truck an its slave cylinder worked with brake fluid... |
#4 | |
Low & Fast!
Thanks Silverpete for coming on board.. Let's see if be can get you some help. If we can not get it here I will move you to a place that can. Can anyone help him with this? Thanks, Trav
yes brake fluid does work... usually the same spec fluid that the vhicle uses in the brake system, ie; dot3 or dot 4 etc.. hope this helps....
#7 | |
Low & Fast!
Thanks for helping him out dieseldr4.
Arrived on a Pale Horse
S10's take brake fluid, not sure on the bigger trucks tho. Does it say DOT 3 on the cap?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
