Old 06-05-2009, 05:12 PM   #1
ChicoSmith
When in doubt throttle out!!!
ChicoSmith's Avatar
3 water pumps later still wobbles??
I have been through two Kragen (Master Pro) pump and now a Bosch and still have the same problems. Pumps shaft wobbles just enough to have the fan "tink" around on something at idle. Can a pulley get spunked and cause this? I've used the same pulley and fan throughout. Oh yeah new Fan Clutch.
Any other ideas.
I've thought about going to an electric fan set up but trying to stay on a tight budget.
ChicoSmith is offline   Reply With Quote
Old 06-05-2009, 05:47 PM   #2
AlienYouth
AlienYouth's Avatar
Re: 3 water pumps later still wobbles??
is it the pump shaft wobbling or the pulley not being straight, or something on the mounting surface keeping it cocked? i have my doubts about it being the pump shaft wobbling.... just my thoughtssss
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 06-05-2009, 07:26 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x2. If you have the same wobble with three different pumps, it's not the water pump shaft. If the pulley is good and there's nothing under it to cock it sideways, there must be something wrong with the fan.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-05-2009, 10:16 PM   #4
100%Chevy
Are you over-tightening the belts?
Mike.
100%Chevy is offline   Reply With Quote
Old 06-05-2009, 11:03 PM   #5
hwyix
The other people gave great advice, but as a shop owner I would never buy stuff from pep boys / autozone / kragen / napa, etc... YMMV.
I work with a lot of others shops that continue to buy from them, they seem to always have to return something like at least 10% of time. I guess for them in their eyes the profit is worth the hassle. Too me I do not want to put junk on my customers cars.
You might have just been given a bad water pump several times in a row. I have seen this with the stores above for fuel pump/timing belts/t-stats/radiator caps. I am talking about in a row. Even a good store or OEM will sometimes give you the wrong or bad part. The only time I have seen several in a row is with the above stores.
hwyix is offline   Reply With Quote
Old 06-06-2009, 01:13 AM   #6
Jtrux
I'm a poor spectator
Jtrux's Avatar
I bought 3 fuel pumps from advance auto and all 3 of them put out too much pressure, flooding the carb. I ordered a Carter from Summit and violoa!! Problem solved. YOU CAN buy 3 defective parts in a row, I did.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 06-06-2009, 01:18 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Lil story.... the only parts store in our small town is a NAPA. I once installed three of their water pumps to get one good one -- one lasted a week, and one was bad out of the box.
I suppose the OP could have gotten three pumps, each with a bent shaft. It seemed unlikely to me, but anything is possible.
- Mike -
RIP El Jay
Old 06-06-2009, 09:44 AM   #8
Shyguy
Junior Member
Shyguy's Avatar
This a true story even though it happened a very long time ago, late 1970's.
I had a Dodge chassis motorhome and the the alternator went bad.
I got 3 bad ones in a row from Kragens before I finally decided to spend more money and went to Napa Auto Parts store. I never had problems with the one I got from them.
I work at chain auto parts store, not one that is mentioned, and have seen problems with the cheaper stuff, but the "Life Time" parts are usually pretty reliable.
The majority of the parts sold now days are not made in the USA, so quality control seems to be not as good on the cheaper parts.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-06-2009, 10:06 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Are you buying the correct water pump? Is your pulley system set up for a short water pump or a long water pump? If it's set up for a short, and you buy a long and tighten the belts, the angled tension on the pulley would probably be enough to destroy the water pump.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
