Hey guys, I just realized there was a 4x4 forum. I have a 69 C20 CST Longhorn. New 350 motor newer 400 trans, I take it out camping all the time. So I am just getting the truck operational in every aspect, Not trying to restore it due to time and money.
So the front end is next. I want to level the truck, give it a cool stance. I heard I can do this with 1 ton springs of the same year. This can will give me a rumored 2 inches in front? Is this so? And if so will the steering deal with it. Also what do it do with me lower A-arm sway bar bushings. Do I need spacers. Where can I get them. I am also ditching the drums for 8 lug discs. Any info would reall help thanks. |
#2 | ||
Re: 69 C20 Longhorn
There really isn't much that you can do to lift a 3/4 ton 2 wheel drive's suspension w/o really affecting the ride quality. Taller/heavier springs will make it very stiff. You can't raise much w/o hitting the upper bump-stops, which makes for an even worse ride.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Grease Monkey
Re: 69 C20 Longhorn
You could use a coil spring spacer. I know it works with the later model trucks, but I'm not completely familiar with the 67-72 2wd setups.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
member
Re: 69 C20 Longhorn
There are spring kits called "Zero Rate" They are about 1 " thick and are used on the front and rear spring perches of 4wd's for minor wheel location adjustments in height and from front to back as well. I found info. awhile back in a 4wd forum. Can I say it? The forum is "Colorado K5"
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 06-13-2009 at 08:22 AM. |
#5 | |
Re: 69 C20 Longhorn
This is not a 4x4..........Zero-rates will not fit the front.
Re: 69 C20 Longhorn
I run a 2" longer coil and a balljoint spacer to correct for alignment. I would recommend a 1.5" spring if I could do it over. This setup allows me to run 33x12.5x17 tires with no rubbing on my 77 c20.
[IMG] ![]() |
