06-06-2009, 09:17 AM | #1 |
Loving the Jimmster
Are the Front springs loaded??
I was told by my father in law that the front springs were loaded? If you just took the a-arm assembly apart they would explode??? any truth
06-06-2009, 09:21 AM | #2 |
Re: Are the Front springs loaded??
not really // if you have a jack under lower control arm and after you seperate balljoint you slowly lower jack and the spring cofalls out // BUT it does make a clunk when it hits the floor
06-06-2009, 09:29 AM | #3 |
Loving the Jimmster
cool the 68 c20 has lower front springs so i thought about swapping them out
06-06-2009, 09:31 AM | #4 |
Junior Member
No, they will not explode.
That being said, caution should be taken when working on a front end. I usually use jack stands on the frame and a floor jack under the "A" arm when dis-assembling. Now struts on the other hand, which are used on newer vehicles, require spring compressors durning dis-assembly of front-end parts. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-06-2009, 10:42 AM | #5 | ||
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-06-2009, 11:08 AM | #6 | |
Explode? No, but they are "loaded". It is not much compression as far as length, but there is quite a bit of pressure involved. Even after the ball-joint is seperated from the lower control arm and lowered, there is still some pressure because the spring is "trapped" in the pocket of the lower arm. You may have to pry it out and it will probably "pop" out.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-06-2009, 10:25 AM | #7 |
I am a Referee of life.
They wont explode but you'll think they did if you just pop them loose without a jack under them.They are under compression and will expand at a rapid rate usually leaving the spring pockets and scaring the crap outta ya if not knocking you out.They can cause serious injury.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 06-06-2009 at 10:25 AM. |
06-06-2009, 02:53 PM | #8 |
its all about the +6 inches
this train of though is due to the struts used in cars for the last 30 years almost. People 'forget' what they don't see, and this is one of them.
As others said already, place the truck on jack stands, and the floor jack under the lower control arm, and then pop the lower ball joint off. Lower the jack and it'll fall out. It may jump 6 inches out, but that's it. |
06-06-2009, 07:36 PM | #9 |
WTB this ad
Link to vids I made showing how to remove and replace front coils...
http://67-72chevytrucks.com/vboard/s...ight=worthless |
06-07-2009, 09:05 AM | #10 |
Loving the Jimmster
Thanks a bunch this will help me out. I am hoping to have the engine in this week, then i can change out the springs!! thanks again
vance |
