Old 06-06-2009, 03:58 PM   #1
soxplayer
Question 19.5 Tire Size
My wife's 67 C20 is an old Forest Service Stepside with ultility boxes. The GVWR is 7500 and according to the owners manual it came equipped with 8-19.5 6 ply front tires and 8-19.5 10 ply tires in the rear. Right now it is on 7.50-16 LT on demountable 8 lug rims. Does anybody now how to determine the diameter of the original tires (i.e. 78,80 or 90 series). The differential is a 4.56:1 and the shorter tires really limit highway travel. I am considereing 235/85 16 on newer tubeless rims but I really want to know how close these taller tires are to the original diameter in order to lower the highway revs to an appropriate level.
soxplayer is offline   Reply With Quote
Old 06-06-2009, 04:14 PM   #2
Cyclone44
Step Brother
Cyclone44's Avatar
Re: 19.5 Tire Size
Welcome from Knoxville Tn.....I will move this where it should get more responses....
Cyclone44 is offline   Reply With Quote
Old 06-06-2009, 04:16 PM   #3
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
Smile Re: 19.5 Tire Size
FROM KNOXVILLE TN!!!
Joe
DREAMS OF A 67 is offline   Reply With Quote
Old 06-06-2009, 05:45 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 19.5 Tire Size
Welcome from NorCal! I tried a couple different tire size comparison sites, but neither lists your original size...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 06-06-2009, 06:30 PM   #5
john
member #16
john's Avatar
Re: 19.5 Tire Size
Heres a site that shows 34.6 diameter for a 8-19.5 10 ply. And welcome to the best truck site.
http://www.sylmar.ca/autoville/tires/truck-609029.jpg
john is offline   Reply With Quote
Old 06-06-2009, 07:12 PM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: 19.5 Tire Size
I'm running 8.00 19.5 12 ply tires on my 1 ton and they measure close to 35" tall. Thats about the tallest tire available for the 19.5 rims and they are hard to find.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-06-2009, 08:26 PM   #7
factorystock
factorystock's Avatar
Re: 19.5 Tire Size
The formula: RPM = MPH x AXLE RATIO x 336 / TIRE DIAMETER. For maximum highway speed without changing the whole rear axle, change out the 4.56 pumpkin with a 4.10 pumkin and use the period correct 19.5" wheels. Tire sizes sometimes vary between 1"-2" from different manufactures. Most 8-19.5 tires are 33" to 35" tall.
factorystock is offline   Reply With Quote
Old 11-08-2011, 01:32 AM   #8
soxplayer
Re: 19.5 Tire Size
Just thought I would dredge this up and give a clear answer. The truck actually has a 5.13:1 axle ratio. The 235/85/16 tires give perfect speedometer and odometer readings so I suspected they are slightly bigger than stock. I eventually found the original spare and it is shorter than the new tires. Long story short: 65 MPG = 3800 RPM = 14 MPG out of a 250 six.
Old 11-08-2011, 08:14 AM   #9
Re: 19.5 Tire Size
Yeah,those 19.5s were a bit short on the sidewall height,just like 16.5s. They were a lower profile diameter. You could probably go to 255/85s for a bit lower RPMs. But,that rear could change right out with a 4.10 with minor work. Just un-bolt the driveshaft and slip the axle shafts out and you can remove the entire differential from the front.
